300 HP Turbine Engine By Rolls-Royce
Postby bullet » Tue Nov 11, 2008 12:53 pm
Rolls-Royce is developing a 300hp turbine engine for use in light aircraft. Doing proof of concept work with Mooney.Weighs half the weight of a similarly powered piston engine. Expected to be available in 18-20 months` time.
bullet
Re: 300 HP Turbine Engine By Rolls-Royce
Postby Beech 200 » Tue Nov 11, 2008 12:58 pm
wow sounds awesome cant wait to see this!!
''dont let your fears stand in the way of your dreams'
Beech 200
Power off Glide
Postby Richard Smit » Tue Nov 11, 2008 1:10 pm
What about getting someone to develop a new 300 hp RADIAL??!!!!!!!!!
Spool-Up
Richard Smit
Postby kevinbark » Tue Nov 11, 2008 1:14 pm
\m/ <(-_-)> \m/
kevinbark
Postby Whirly » Tue Nov 11, 2008 1:19 pm
Is that not the engine that Robinson is putting into their latest flamethrower..............the R66?? :twisted:
Jacobus Adriaan
(FSS,SSAW,NSC)
Of all things in life I have lost,I think I miss my mind the most!!
One of very few people never to have posted anything under the "NO" topic!!
I live by Hook's law........he said Murphy was an optimist!!
Postby bullet » Tue Nov 11, 2008 1:36 pm
No,it`s a completely different engine.Apparently it will also be built at the same plant as the 250 series engine for the Robinson R66 which you are referring to.
bullet
Postby Mauler » Tue Nov 11, 2008 2:20 pm
For one of those, I WON'T sell the Mooney! Anyone wanna buy a half-life 0-360?
First rule in politics: never believe anything until it's officially denied.
Mauler
Postby bullet » Tue Nov 11, 2008 2:56 pm
The RR website states the following in respect of the TBO for the turbine of the Robinson R66:
Overhaul interval (preventative maintenance).............................2000 hours
Gas producer turbine life......................................................2000 hours
Power turbine life...............................................................4000 hours
Compressor impeller life.......................................................10 000 hours
bullet
Postby smartz » Tue Nov 11, 2008 5:27 pm
And now for the £1,000,000.00 question: How much is it going to cost?
What do you think would be the threshold price-tag for aircraft owners? In other words, the price at which it becomes economical to dump the piston and bolt on the turbine?
Also, if the engine is 50% lighter than equivalent piston, the W&B problem would preclude it replacing piston engines on certain types.
But even so .... I'm delighted to see that a big company like RR is "investing" in the "small" a/c segment. Hopefully we will see even smaller turbines in the sub-200 shp range becoming available on the market some day (soon). I hope that this encourages other aircraft engine manufactures to consider extending turbine technology into this segment of the market. This can only be good for GA.
Never let an aircraft know that you are in a hurry.
smartz
Hee Hee I'm Flying
Postby StuartA » Wed Nov 12, 2008 3:01 pm
Video at http://www.avweb.com/avwebflash/exclusi ... MP=OTC-RSS
Also:
Rolls Launches GA Turboprop Engine Jul 29, 2008
By John Morris/EAA AirVenture 2008, Oshkosh
Rolls-Royce challenged general aviation to step up its use of turboprops with the launch at Oshkosh today of a next-generation 350-450 shp turboprop engine named the RR500.
"The RR500 is ideally positioned to capture significant market share in the light, fixed-wing general aviation segment," said Ken Roberts, president of Rolls-Royce helicopter business, which embraces turboprops too. According to the Rolls-Royce ten-year market forecast, 2,500 to 3,000 of these light aircraft will be delivered annually between 2010 and 2020.
"Not only does the RR500 deliver cost-effective turbine power in a lightweight, affordable, compact design, but it also appeals to a broad segment of the market historically limited to reciprocating engines."
The new engine, based on the RR300 turboshaft engine for helicopters unveiled last year, comes in just below the smallest Pratt & Whitney PT6 engines (580-920 shp) and the Walter M601 (500-800 shp). On paper it appears to compete head-to-head with Rolls's own Model 250 (around 400 shp) that powers various models of Maule, Cessna and Bonanza.
The 250, however, has always been regarded by the general aviation market as "expensive," Roberts said. The RR500 will cost "substantially less" than the 250, due to the clean-sheet design allowing the latest in design, materials and manufacturing techniques. "The Model 250 is very, very popular, and this allows us to offer a lower cost alternative," he said. Industrialization is significantly more advanced now than when the 250 was originally designed, he added.
The RR500 is basically a growth version of the RR300. "We were looking at the 300 shp market but decided that the RR300 was just not big enough to meet the altitude and hot-and-high requirements that many aircraft need," Roberts said. Thermodynamically, the new engine "will be north of 500 shp at sea level," and will offer 400-450 shp for takeoff, around 350 hp for climb, and 320 hp for a cruise speed of 220 kt at 12,000 ft.
"Our preliminary target is new OEM aircraft; retrofits and conversions will be secondary," Roberts said. He is convinced the engine will prove popular as 100LL Avgas becomes harder to find and is eventually phased out. "This engine will burn a wide variety of kerosene-based fuels including the Russian and Chinese blends," he added. "We've already had a lot of market interest."
Certification is expected in less than three years.
While RR300 engines are painted blue, the RR500 will be green--a color that is bound to symbolize its benefits for the environment as well.
Rolls-Royce on Monday announced that Rotorway International will explore using the the RR300 turboshaft engine that was launched last year for the Robinson R66 helicopter. Rotorway is the world's oldest and largest manufacturer of kit helicopters.
Stuart
StuartA
Incorrect Read back of ATC clearance
Return to General Aviation Chatter
Who is online
Users browsing this forum: Alan Robertson, Baidu [Spider], Bing [Bot], Bowie, cx45338, Datus, frikie, gordloewen, Mauler, MSNbot Media, Yahoo [Bot] and 19 guests
