FS9 & FSX Screenshots
capetonian
Unread post by capetonian » Fri Aug 18, 2006 1:32 pm
Use this thread to post your Flight Simulator Screenshots :)
My Baby Boeing climbing out of Birmingham. (FS2002 scenery)
Edit: edited the title to fit in with Snoopy's titles :)
Andrew Spring.
The all new *free* Marketplace for Aircraft and accessories: www.planeshopping.com
I'm a self-confessed Albatross Junk
Skype me! My skype nick is dakleton
Snoopy
Unread post by Snoopy » Fri Aug 18, 2006 3:48 pm
Not my screenshots...But look at the quality of this FS2004 scenery...its Switzerland Pro payware scenery...makes FS9 look pretty good compared to FSX.
If you've seen the Mirage 2000 video of the Swiss Air Force in the Alps you'll identify these valleys.
capetonian
Unread post by capetonian » Fri Aug 18, 2006 4:14 pm
Snoops, ..
Which Mitchell is that?
Andrew Spring.
Snoopy
Unread post by Snoopy » Fri Aug 18, 2006 5:02 pm
MAAM...I see its payware now..I thiunk it was released as freeware orginally. See MAAM.org...funds all in aid of aviation heritage.
http://www.maam.org/flightsim/PACKAGES/BT.htm
capetonian
Unread post by capetonian » Fri Aug 18, 2006 6:44 pm
Guess I'll have to let the Mitchell slide,. I have too much payware already :( (need to save kudos for the real aerie)
A chopper from Hovercontrol, the scenery is the excellent Dubai scenery from FlyTampa! Seen here landing on top of the Hotel.
One of the terminals at Dubai, note the detail through the windows.
Wonder if this is what it will look like when the first Emirates A380 arrives in Dubai.
The Perfect Flight (Payware) A380.
Andrew Spring.
Christo
Unread post by Christo » Fri Aug 18, 2006 6:53 pm
Snoopy7 wrote:Not my screenshots...But look at the quality of this FS2004 scenery...its Switzerland Pro payware scenery...makes FS9 look pretty good compared to FSX.
Shouldn't you be comparing apples with apples?
Snoopy
Unread post by Snoopy » Fri Aug 18, 2006 7:08 pm
Again I believe MS should have taken the trouble to see what was available for FS2004 including the work introduced by payware designers, and improve on that.
What I am saying is; it looks pretty good compared to the FSX apples I've seen. I can't wait to see the real macoy....and yes perhaps the demo doesn't do the new software justice.
Remember to upgrade to FSX means there is a considerable hidden investment to be made in hardware - its not just the software to be purchased....so that needs to be weighed into the "apple basket" as well.
For some this could mean a R6000-R8000 investment in new hardware to run software costing R450. And R3000 will buy a lot of payware for FS9.
When the young apples arrive we'll take another look....
Another comparison would be to take note of any improvements to the Cessna, Mooney, Beech 350 and the Baron models in terms of more realism.
capetonian
Unread post by capetonian » Fri Aug 18, 2006 8:36 pm
Snoopy7 wrote: Remember to upgrade to FSX means there is a considerable hidden investment to be made in hardware - its not just the software to be purchased....so that needs to be weighed into the "apple basket" as well.
I only switched to FS9 (from FS8) at the beginning of 2006. I had bought some payware scenery (UK Airports and Spanish Airports) and payware aeries (Caranado, Captin Sim L-39, SF260 and one I can't remember) in the past and I just did not feel like forking out money for new scenery or aeries.
I finally made the switch for the better AI programmingand the better weather. Now I have quite a few payware packages both aeries and scenery and I intend to fly those for the next year or two, at least. I pull 30 frames now under most conditions, sure I don't have everything maxed out but I have it high enough.
I will definatly like to try FSX out when it gets here, same as I did when FS9 was launched. but it'll be on the pc for a weekend or so and then It will be removed.
Next time I upgrade the pc I'll think of getting FSX. (which should by that time have all the release bugs ironed out)
Andrew Spring.
trimotor
Unread post by trimotor » Sat Aug 19, 2006 7:08 pm
Short Finals to KRDU - Raleigh-Durham in th USA in the Aeroworx B200
8)
Close in multiplayer action with Piper Tri-pacers at PASI :roll:
Ger
Closest Airfield: EGFH
Unread post by Ger » Mon Aug 21, 2006 9:41 pm
hey beech, how do you get the extra info (heading airspeed etc) to come up on the screen? also can you get these when you view from outside, EG, for landing?
thanks
trimotor
Unread post by trimotor » Mon Aug 21, 2006 9:46 pm
Ger,
Just hit Shift & Z together. It stays up top in all views :D
hjs
Lining Up - unmanned
Unread post by hjs » Tue Aug 22, 2006 8:03 am
Hi beech210cm
Like to say hello
hjs
Stephan Rossouw
Unread post by Stephan Rossouw » Wed Aug 23, 2006 7:22 am
Some of my "fun" flights yesterday...
All photos Copyright Stephan Rossouw Photography 2017
Home Page:
http://www.stephanrossouw.co.za
Jaco P
Unread post by Jaco P » Wed Aug 23, 2006 9:28 am
Here is a couple of mine...
skyguy
Unread post by skyguy » Mon Aug 28, 2006 11:56 am
SAA B738 off to FNLU:
Beaver (FSX Demo):
integrity: "doing the right thing when nobody's watching"
Return to “Virtual Aviation”
