Anyone want to share orthophoto tiles? (XPLANE)
Closest Airfield: FASY
Has liked: 199 times
Been liked: 97 times
Unread post by Mrb13676 » Sun Apr 22, 2018 5:39 pm
By my calculations there are about 125tiles covering South Africa.
Have spent a lot of the weekend building tiles and have about .... drumroll... 21.
Seems like the ideal thing to share?
Thoughts?
Mike Blackburn
ZU-IBM - Sling4 Turbo s/n 009
Brend@n
Flying to unmanned aerodrome
Closest Airfield: FAOR FARA
Re: Anyone want to share orthophoto tiles? (XPLANE)
Unread post by Brend@n » Mon Apr 23, 2018 12:20 pm
How do the orthophoto tiles compare to g2xpl?
Brendan
Unread post by Mrb13676 » Mon Apr 23, 2018 2:39 pm
Not sure at all actually. - I THINK ortho4XP includes the mesh into it’s tiles. But i may be wrong..
Mike Blackburn
hennies1
Engine Still Cranking
Unread post by hennies1 » Mon Apr 23, 2018 8:26 pm
What is the size of a tile? Just bought x plane 11 today and need tiles
merlinsarrow
Unread post by merlinsarrow » Tue Apr 24, 2018 9:28 pm
Depends on the size of the zoom level you select. Normal ZL16 is about 2Gig per tile, ZL17 is 6Gig and i have a ZL18 tile that is about 18Gig for 1 tile from Bing (BI)
Unread post by Mrb13676 » Wed Apr 25, 2018 8:35 am
Yeah in retrospect it probably wouldn’t work to share these - copyright issues aside they are simply too huge. I’m going to need an extra HDD just for Orthophoto tiles. Add the HD mesh at about 2gb per 10x10degree sector and it starts getting silly. But WOW, it looks so nice compared to other sims and without.
Can almost do VFR flying round Jhb with the ZL17 tiles....
Mike Blackburn
hennies1
Unread post by hennies1 » Wed Apr 25, 2018 1:07 pm
When generate of tile you need two files , tile file Plus the overlay. What do you do if you whant to ad a nother file and overlay to your custom scenery. name of tile are different but not the overlay. Please give advice.
LegalEagle
Closest Airfield: FAVG
Unread post by LegalEagle » Fri Apr 27, 2018 4:58 pm
Hi MrB,
It would be amazing to be able to share these files, given the amount of work that goes into them, but I'm afraid that due to their size it becomes a little impractical.
I'm currently building tiles around the Durban area, moving outwards along the coast and inland. Using ZL17 for the base and ZL19 for key areas such as airports or other points of interest. Over that I've downloaded the OSM data for custom overlays. Looks amazing without too much tweaking.
The OSM data seems to help with buildings etc, and accurate placement of the autogen scenery as compared to the stock XP11 OSM data. Not really sure why they differ though as they're based on the same data.
LE
hennies1
Unread post by hennies1 » Sat Apr 28, 2018 7:40 pm
Do it take a lot of internet data to generate this tiles?
PatrickJames
Unread post by PatrickJames » Tue Jul 17, 2018 7:16 pm
Yes Mike. I am aboutto embark on creating tiles. For South Africa. Let's collab. We can use a dropbox or file share program to share tiles. I am on a Mac.But have Parallels. Are you keen toCoLab? Iam looking at only zL17 -19.
PatrickJames
Unread post by PatrickJames » Tue Jul 17, 2018 7:21 pm
Hi MrB,
LE
Hi legal eagle, keen to colab. I have contacted Mike also about this. Let's do this together. I am learning Ortho4XP am on a mac but have parallels.
You keen? Ilive in CT and want to do the coastal region from CT up to Durban. Maybe we can split up the task between the 3 of us and cover SA and MOZ?
Unread post by Mrb13676 » Wed Jul 18, 2018 2:09 pm
ImageUntitled by Mike Blackburn, on Flickr
This is what I have ZL17 CPT and the 4 blocks around Jozi The rest ZL16. 2-3GB for XL16 per block and between 5-7Gb for ZL17
I imagine ZL19 must be incredible BUT..... how massive will those tiles be?
Mike Blackburn
csparksfly
Has liked: 81 times
Unread post by csparksfly » Wed Jul 18, 2018 4:08 pm
Out of curiosity, could you perhaps attach a sample of what the scenery looks like ?
Thanks
Skill and luck - always have enough of both
Has liked: 16 times
Been liked: 335 times
Unread post by cage » Thu Jul 19, 2018 10:29 am
On a modern fibre link those sizes are not that big, it's easy to move that data around quickly. I download far more than that.
Unread post by Mrb13676 » Thu Jul 19, 2018 3:31 pm
true - we're still stuck in the 384kbps mindset...
Mike Blackburn
Return to “Virtual Aviation”
