More info added in later post below. Two Aeronca Champions and spare engines and hangar for sale
Forum rules
No commercial adverts please (If your intended post is of a commercial nature, then please follow this link and read BEFORE you post : http://www.avcom.co.za/phpBB3/viewtopic.php?t=54617). If you are advertising for a friend - the ad must contain the owners contact details. If you wish to advertise in the commercial section: - email ads@avcom.co.za for more information. Model Aircraft and non aviation item's have their own section - any posted here will be deleted.
sumbloke
Closest Airfield: FAPM
Re: Two Aeronca Champions and spare engines and hangar for sale
Unread post by sumbloke » Tue Aug 20, 2019 6:54 pm
What happened to these in the end? Where they for sale in flying condition?
Has liked: 99 times
Been liked: 103 times
Unread post by V5 - LEO » Tue Sep 17, 2019 10:13 pm
...would also like to know?
Has liked: 490 times
Been liked: 143 times
Unread post by ACE MAN » Wed Sep 18, 2019 7:51 am
Well, phone him
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
Has liked: 503 times
Been liked: 379 times
Unread post by Ugly Duckling » Wed Sep 18, 2019 8:10 am
Well phone him
Contact details of owner:zero eight three double nine three six eight double six
Has liked: 99 times
Unread post by V5 - LEO » Wed Sep 18, 2019 11:35 am
...contacted him and still available! :)
Desert rover
Mags On
Unread post by Desert rover » Wed Sep 18, 2019 4:41 pm
If I didn't already have two Champs I would have bought these two.
Champs ( the forefather of the Citabria, Decathlon and Scout) are the most underrated aircraft for very reasonable prices these days.
And it flies circles around a J3 :wink:
aeronca2
Closest Airfield: springs
Unread post by aeronca2 » Thu Sep 19, 2019 11:45 am
Two Aeronca Champions, two spare Continental engines and other spares for sale.
The Aeronca Champion was designed to be an improvement on the Piper J3 Cub. The Champ has no vices and is one of the very few taildraggers that allows you to see the runway in the 3-point attitude from the pilot seat. (Solo from front or rear seat). Compared to the J3, it is better/faster because the engine is fully cowled, aileron rigging internal and no bungees etc. The Aeronca Champ can still be bought new for about R2.5M. They are on the same type certificate as the Citabria and spares are still available. These two aircraft are the most original of the few in SA although both aircraft are in Part 24.
The Champs have 50 litre nose tanks and burn 16 to 18 litre per hour at 85 mph true in smooth air. I did my PPL in ZS-BBS at Springs Airfield in Summer; they climb steeper than a C152.
REG NR: ZS-BBS
Aircraft Make and Type: Aeronca Champion 7AC (In part 24 – the old LS1).
Year Model: 1947.
Airframe Hours: 4197 hrs.
Engine Type: Continental A65-8.
Engine Hours: 1112 hrs SMO, 134 hrs STO (1800 hrs TBO).
Magnetos: 134 hrs since 500 hr inspection.
Prop Type: McCauley 1B90 metal.
Prop Hours: 306 hrs since overhaul – no nicks.
Covering: Good condition Ceconite 101.
Work To Be Done: Aircraft is airworthy.
Reason For Sale: Retiring from flying.
Price: R300 000.00 (ONCO).
REG NR: ZU-ABG (ZS-BBV)
Year Model: 1947.
Airframe Hours: 3760 hrs.
Engine Hours: 867 hrs SMO (1800 hrs TBO).
Magnetos: 135 hrs since 500 hr inspection.
Prop Type: McCauley 1B90 metal - no nicks.
Work To Be Done:
Wings to be recovered. The aircraft was removed from service when the wing’s cotton fabric became un-safe – now the engine is run regularly until the oil is hot. Two rolls Ceconite 102 is available for covering.
Price: R200 000.00 (ONCO)
Log books for both Aircraft and Engines.
I have NEW spares: - 3 Maule solid tailwheels + 1 assembly, tail leaf springs, tyres, spark plugs (shielded and un-shielded), valves, rings etc. Also, all manuals and Aeronca maintenance books etc.
One set J3 Cub leaf springs.
Spare Engines.
C85 -12 Engine with Continental blanks on the starter and generator drives.
The engine was bought from the AMO at Secunda in pieces with no log books. It is now almost finished overhauled but still in pieces.
New Cam.
New Cam Followers.
New 15 thou Pistons, Rings plus Piston Pins.
New Oil Pump.
New Valves.
New Bearing Set.
New Conrod Bolts.
New Through Bolts.
New Gasket Set.
New Ventury/Jets for carb - needs to be done still.
The cylinders were overhauled by the late Rockey at Springs AMO.
Case and Crank magnefluxed. – Case through bolts tapped for helicoils (Standard better than new repair) – helicoils not installed yet.
Bendix Mags need overhaul.
I’m sure I forgot some other new stuff but I think you get the Idea of what it is.
I have R50K in it and would like to get it back if possible.
A65-8 Engine stripped by Secunda AMO which had obviously low hours – cylinders still at standard and useable size. No log books. Needs pistons, bearings, gaskets, magnetos. Crank, metal parts and case magnefluxed. Crank polished. Then I have extra cranks, conrods, pushrods, carbs etc.etc. The AMO sold all their Small Continental second hand spares to me. +/- R20K
hugo_visser
Been liked: 62 times
Re: More info added in later post below. Two Aeronca Champions and spare engines and hangar for sale
Unread post by hugo_visser » Thu Sep 19, 2019 12:49 pm
Well am interested BUT, NO NZ pilot will fly any SA aircraft, NZ CAA are not happy with SA.
Hugo.
Has liked: 59 times
Been liked: 142 times
Unread post by GL » Fri Nov 01, 2019 5:54 pm
Hugo.
Very interesting - what about ICAO compliance? - what is the NZCAA problem with SACAA?
Last bumped by aeronca2 on Fri Nov 01, 2019 5:54 pm.
The essentials to happiness:
• someone to love,
• something to do,
• something to hope for
Guy Leitch
Return to “Aircraft for Sale”
