Grumman Agcat G164B for sale
Forum rules
No commercial adverts please (If your intended post is of a commercial nature, then please follow this link and read BEFORE you post : viewtopic.php?t=54617). If you are advertising for a friend - the ad must contain the owners contact details. If you wish to advertise in the commercial section: - email ads@avcom.co.za for more information. Model Aircraft and non aviation item's have their own section - any posted here will be deleted.
Tweety
Engine Cranking
Unread post by Tweety » Mon Jul 01, 2019 9:55 pm
Grumman Agcat G164B (tall tail)
1976 model. Aircraft is ready to work.
Airframe Hours 8682 approx
Engine Type and Hours Covington reman R1340 radial, 900 hrs remaining
Prop type and Hours : Hamilton Standard 12D40 with sleeved counterweight bolt STC, approx 400 hrs remaining
Avionics and other equipment: Agnav Guia Silver , Icom VHF. Transland spreader. 24 volt fan brake coupled to 4 blade Lane fan and Transland spray pump. Bottom load fuel, 80 USG. Stainless steel dropped booms with CP check valves.Image
Reason for sale: upgrading to turbine
Viewing Location: Bela Bela, Private airfield
Price: R 1,900,000 (Inc of VAT/No VAT applicable)
Other information:Spare airframe and wings, accident damaged. Complete spare engine, needs shockload, 600 hrs remaining. 2x full sets of undercarriage legs. One full set of tires, front and back. Spare starter motor, Jasco alternator, gravity fed carburetor , 3 x Bosch magnetos, 1x oil cooler , extra 12D40 Hamilton Standard prop hub with one serviceable prop blade.
Contact details of owner:0824566799 Craigh
Pictures:a challenge attaching photos, I will Whatsapp to interested partiesImage
Life is hard. It's harder if you are stupid: John Wayne.
Learn from other's mistakes, you won't live long enough to make them all, yourself! :shock: :shock:
Tweety
Engine Cranking
Re: Grumman Agcat G164B for sale
Unread post by Tweety » Wed Jul 03, 2019 5:51 pm
Bump
bullet
Unread post by bullet » Thu Jul 04, 2019 8:11 am
Does it run on avgas only or mogas as well (ops normal, not only emergencies)? Thanks.
Tweety
Engine Cranking
Unread post by Tweety » Thu Jul 04, 2019 8:17 am
Bullet, the P+W R1340 can run on both. However I prefer Avgas only. There is a mogas stc available from Petersen’s, which is basically a sticker on the fuel tank and a metal tag fitted to the engine cradle.
bullet
Unread post by bullet » Thu Jul 04, 2019 5:45 pm
Thanks Tweety.
Tweety
Engine Cranking
Unread post by Tweety » Fri Sep 13, 2019 5:24 pm
Bump
Tweety
Engine Cranking
Re: SOLD Grumman Agcat G164B for sale SOLD
Unread post by Tweety » Thu Sep 19, 2019 6:38 pm
Aircraft is SOLD
Return to “Aircraft for Sale”
