AIRCRAFT WANTED
Forum rules
No commercial adverts please (If your intended post is of a commercial nature, then please follow this link and read BEFORE you post : viewtopic.php?t=54617). If you are advertising for a friend - the ad must contain the owners contact details. If you wish to advertise in the commercial section: - email ads@avcom.co.za for more information. Model Aircraft and non aviation item's have their own section - any posted here will be deleted.
ABERMAN
AIRCRAFT WANTED
Unread post by ABERMAN » Tue Jul 16, 2019 12:25 pm
NTCA
Engine : Rotax 912 or UL 260i
Prefer with a Ballistic parachute fitted
Budget Max : R 370 000
Contact : Ami Berman 082 641 8596
ABERMAN
Re: AIRCRAFT WANTED
Unread post by ABERMAN » Thu Sep 12, 2019 11:11 pm
Bump
Airfire
Re: AIRCRAFT WANTED
Unread post by Airfire » Fri Sep 13, 2019 9:37 am
Yesterday is history.
Tomorrow is a mystery.
But today is a gift.
That's why it's called the present.
ABERMAN
Re: AIRCRAFT WANTED
Unread post by ABERMAN » Fri Sep 13, 2019 2:15 pm
Thanks Airfire :D would one be able to "night rate" e.g. this Ikarus C42B if the aircrafts POH state's VFR day only in it's current setup , If one had to install all avionics , lights ECT the SACAA have listed for NTCA ,would it be possible to get it approved for night vfr ? If anyone might know or has gone through the process , it's all a bit confusing as some say you can some say you can't because the POH/AFM overides . I have heard some Cheetahs ( similar weight category ) out there have been approved for night vfr not sure if this is correct .
Return to “Aircraft for Sale”
