Goblin 500 Release.
Goblin Hobbies is the Exclusive Distributor for Goblin helicopters for South Africa. We have a full online e-commercial website www.goblinhobbies.co.za. We also have dealers in PE and JHB and more are signing up as we speak.
Moderator: Goblin Hobbies
Goblin Hobbies
Commercial Supporter
Goblin 500 Release.
Unread post by Goblin Hobbies » Fri Dec 28, 2012 7:15 pm
The long anticipated Goblin 500 release date will be announced soon. Limited kits will be release with the first batch due to the high demand world wide. For those who are wanting to pre-order best you do it now.
Please email us at sales@goblinhobbies.co.za
Exclusive Distributors for Goblin Helicopters, AleeS Rush 750, Outrage Fusion 50, Gens Ace Batteries, Beastx, Rail Blades, MKS Servo and MSH Heli and Brain FBL in SA.
Goblin Hobbies
Re: Goblin 500 Release.
Unread post by Goblin Hobbies » Mon Dec 31, 2012 7:13 am
One of the 2 colour schemes for the SAB Goblin 500. Coming soon.
ktmflyer
Stall training
Unread post by ktmflyer » Sun Jan 06, 2013 12:39 pm
All specs there. Pre-order now and get your kit in the first batch.
http://www.goblinhobbies.co.za/sab-gobl ... white-kit/
General Specifications Electronic Specifications
• Main rotor diameter: 1136mm (with 500 mm blades)
• HPS Head (FBL Only)
• Main blade length: 470 to 500mm
• Tail rotor diameter: 226 mm
• Tail blade length: 80 mm
• Main shaft diameter: 10 mm
• Tail shaft diameter: 5 mm
• Spindle shaft diameter: 8 mm
• Gear Ratios 6.9-11 : 1
• Weight including electronics: 1900 g (excluding flight battery).
Special Features:
• Full carbon fiber boom
• Quick release battery tray system
• Sacrificial breaking point for landing gear and boom
• Unique “inside the boom” tail push rod design
• Cyclic Servos: Mini size (36mm)
Normal and 3D Flight: Hitec 5245 MG, Align DS510M or DS515M, Savox SH1250, Graupner DES 678 MG, MKS DS-9660A, Futaba 9650
HARD 3D: Futaba BLS153, Graupner HBS660 HV, JR DS3717 HV, HITEC 7245 MG HV, JR DS3711 HV
• Tail Servo: Standard size (40mm)
• Typical Speed Controller: 80/100A
Normal and 3D Flight: Kontronik Koby 90, YGE 100 LV
NARD 3D: Kontronik Jive 100 LV, YGE 120 LV, CC Talon 90
• Motors: (Max Diameter: 52 mm, Max Height: 52 mm)
Normal and 3D Flight: Scorpion HK-4015-1070, Quantum 4115-1200
HARD 3D: PYRO 600-1200, Scorpion, HKIII-4020-1100/1350
• Flight Battery: (Max Dimensions: 52x53x180mm)
6S 2800/4500 mAh.
• Identical concept as Goblin 700
• Simple and effective design
• Carbon fiber boom for maximum rigidity
• HPS (High Precision Head System)
• 10mm high strength steel main shaft
• 8mm high strength steel spindle shaft
• Large tail pulleys for increased tail authority
• Dampened tail system for increased vibration tolerance
• Unique, extremely rigid transmission design
• Stiffness of the model defined by a single component
• Heat tolerant primary drive belt
• Carbon fiber tail push rod hidden inside the boom for an aesthetically pleasing, unique design
• Nylon bolt break-away system to preserve the boom during a crash
• Landing gear mounting brackets don’t require bolts to be installed. The brackets are a break point during a crash preserving frames and other important parts
• Plenty of room for electronic components
• Mini size cyclic servos
• Direct and geometrically correct servo placement
• Standard size tail servo
Goblin 700
Gens Ace
MKS Servo
XNOVA
Goblin Hobbies
Unread post by Goblin Hobbies » Sat Jan 12, 2013 12:38 am
Ok So who wants a SAB Goblin 500 Combo?
Goblin 500 colour of your choice.
Castle Talon 90
Brain FBL
Scorpion HK4015-1070
Combo price R9999.99
With MKS Servo 3x DS9660A+ and DS760
Super Combo R12999.99
Goblin Hobbies
Unread post by Goblin Hobbies » Mon Feb 04, 2013 3:31 pm
Who wants a Goblin 500? Are you ready
Goblin Hobbies
Unread post by Goblin Hobbies » Wed Feb 06, 2013 11:30 am
MMMM.....The 12th Feb is near guys.....
better hurry as the second batch release date is not even announced yet. This means if you loose out now you could wait for the next batch...
Goblin Hobbies
Unread post by Goblin Hobbies » Tue Feb 12, 2013 1:26 pm
Goblin 500 has arrived and available now.......
Goblin Hobbies
Unread post by Goblin Hobbies » Wed Feb 13, 2013 6:31 pm
Goblin 500:
Goblin Hobbies
Unread post by Goblin Hobbies » Sun Feb 17, 2013 8:27 pm
all done and flying well...
Return to “Goblin Hobbies”
