DJI Innovations NAZA-H
Goblin Hobbies is the Exclusive Distributor for Goblin helicopters for South Africa. We have a full online e-commercial website www.goblinhobbies.co.za. We also have dealers in PE and JHB and more are signing up as we speak.
Moderator: Goblin Hobbies
Goblin Hobbies
Commercial Supporter
Unread post by Goblin Hobbies » Mon Jan 14, 2013 7:09 am
Hi Guys,
We have been appointed by DJI Innovations as their distributor for NAZA-H FBL. The NAZA-H will arrive soon to SA.
The Naza-H autopilot system is a new platform designed for the helicopter model enthusiast. It inherits the Naza series’ All-in-One design with an inner damping and many other built-in high performance functions (tail gyro, flybarless, and multiple flight control modes) and it also supports D-BUS. With the optional GPS module, stability is no longer a problem. From novice to aggressive 3D, the Naza-H perfectly meets the needs of different flying styles. It is not just another FBL controller; it is the best choice for the discerning model helicopter pilot.
All-in-One Design
Built-in Tail Gyro/Flybarless Supported
Support for Multiple Electric Helicopter Platforms
Advanced Attitude and Control Algorithm
Optional GPS Module
Multiple Flight Control Modes/Intelligent Switching
D-Bus Supported
Independent LED Module
Semi-auto Take-off & Landing (Will Be Available in The Following New Firmware)
Naza-H has inherited the All-in-One design of the Naza series of autopilot systems. With the innovative All-in-One design, it contains inner damping, controllers, a 3-axis gyroscope, a 3-axis accelerometer and a barometer in its light and small main controller. It simplifies installation and saves space and weight and its firmware can be upgraded over the internet.
The high-performance FBL (flybarless) system, with a linear and smooth control feeling, is specially designed for model enthusiasts, especially hard 3D flight. The system fully meets the requirements of the novice and professional pilots and more importantly you can also set different flight styles anytime you want. The system has plenty of advanced functions, such as the pirouette compensation and auto trim which make you can feel the ease of stabilization as well as experience the hard 3D flight.
This feature will be available in the following new firmware of Naza-H.
In【GPS Atti. Mode】or【Atti. Mode】, requiring only pushing the throttle (collective pitch) stick gently to take-off, the Naza-H will be in charge of the cyclic pitch/roll stabilization. The whole flight can be completed in one flight mode, which is very convenient for novice helicopter pilots
Naza-H is suitable for a variety of electric helicopter platforms from small to large, such as 450, 500, 600 and 700 size, etc. At the same time Naza-H supports different swashplate types. In addition to the most commonly used 6 types of swashplate, users can also use virtual swashplate rotation to fine tune the helicopter characteristics
Naza-H can measure the servo voltage and can also measure the power battery voltage if the customer uses the DJI BEC. Users can set a safe voltage threshold according to their usage, when the voltage is lower than the preset voltage, the main controller will raise an alarm through the LED indicator
Naza-H inherited the high stability technology of DJI autopilot systems. It combines a GPS (optional), a 6-DoF inertial measurement unit, a magnetic field meter, and a barometric altimeter with the most robust algorithms in robot control theory. With the advanced GPS/INS sensor fusion algorithm technology and the highly robust H-infinity control as the foundation, it makes the whole system more accurate even in high vibration and high mobility environments. All these ensure the helicopter always maintains flight stability, mobility and precision, all of which makes flying easier.
The plug and play Naza-H GPS module can provide accurate positioning. With the GPS Module, Naza-H can have the longitude, latitude and altitude locked even in windy conditions to achieve precise hovering within a small area.
Naza-H offers three control modes: GPS Attitude Mode (with optional GPS module), Attitude Mode and Manual Mode. Customers can switch between the three modes using the transmitter
Naza-H supports both ordinary receivers and the Futaba S-Bus receiver. The S-Bus receiver uses only one servo cable to connect S-Bus and the Naza-H, utilizing seven channels of the receiver. The installation is very neat and tidy due to less wiring.
The Independent LED module makes the indication of the flight status and the system status to the ground much clearer. The pilot can get information more quickly and more conveniently, even at night, he/she can get real-time flight information feedback through the LED flashing frequency and colour. In addition, the module has a USB interface, which is used for parameter settings and firmware upgrade.
Through the Naza-H you can set the intelligent failsafe for protection, which guarantees the aircraft will automatically hover when the Tx signal is lost.
The independent BEC module, with a wide voltage input (11V-52V) and a variable voltage output (5.8V, 7.4V) can power not only the main controller, but also the servos and receiver. Users can change the output voltage according to their servos, and stable output current is provided without an extra battery pack. The use of the BEC makes the aircraft lighter and the voltage more stable, plus less batteries to worry about.
The user interface of the assistant software has been comprehensively updated, and instructions will automatically appear which is very convenient. In addition, on the left of each menu section there is detailed introduction. The logical design makes your parameter settings more simple and convenient. Like other DJI products the Naza-H firmware can be upgraded online.
Exclusive Distributors for Goblin Helicopters, AleeS Rush 750, Outrage Fusion 50, Gens Ace Batteries, Beastx, Rail Blades, MKS Servo and MSH Heli and Brain FBL in SA.
Goblin Hobbies
Re: DJI Innovations NAZA-H
Unread post by Goblin Hobbies » Tue Jan 29, 2013 10:46 am
STock has arrived.....
cabeng
Closest Airfield: Rotorua -NZRO
Unread post by cabeng » Thu Jan 31, 2013 9:26 pm
And I hear Ill be testing one soon in the Bay :roll:
Clearly Weekends are made in china . They simply dont last !
Goblin Hobbies
Unread post by Goblin Hobbies » Fri Feb 01, 2013 1:37 am
cabeng wrote:And I hear Ill be testing one soon in the Bay :roll:
Enjoy the auto pilot :D :D :D
Goblin Hobbies
Unread post by Goblin Hobbies » Thu Mar 14, 2013 4:10 am
DJI NAZA-H on less 20% sale. Get yours now while stock lasts.
http://www.goblinhobbies.co.za/dji-innovations/
Goblin Hobbies
Unread post by Goblin Hobbies » Sat Jul 20, 2013 6:14 am
Hi Guys
Take a look at our ON PROMOTION page. NAZA-M or NAZA-H combo now only R2999.99 while stocks last. Happy shopping
http://www.goblinhobbies.co.za/index.ph ... on-38.html
Return to “Goblin Hobbies”
