Zenith CH701 STOL
The Zenith and Zenair aircraft covering some 22 different models
Bundu
Mags On
Zenith CH701 STOL
Unread post by Bundu » Wed Dec 10, 2014 8:41 pm
Disuccion on any aspects of the Zenith / Zenair CH701 series
Andrew Conroy
Re: Zenith CH701 STOL
Unread post by Andrew Conroy » Thu Dec 11, 2014 6:25 pm
Thought I might add a picture. :D
Willie
Closest Airfield: Hippo Pools
Unread post by Willie » Fri Jan 29, 2016 3:18 pm
Omdat ek in die bos bly het ek nou besluit om ook 'n Jeep te koop. Ek hoop dit is so goed soos al die Youtube videos. Dit het 'n Rotax 912ULS enjin in.
ZU-DSV is op pad. :D
ZS-UJC Hatz Bi-plane
ZS-UGS Evans VP 2
ZS-UNC & ZS- UUJ KR2
Beachcraft Musketeer ZU-VMM
ZU-EJD Thorp T-18
Jabiru J400 ZU-VHB
Zenith 601 XL ZU-DVN
Partenavia ZU-FZS
Flooi
Closest Airfield: FAHG
Has liked: 24 times
Been liked: 16 times
Unread post by Flooi » Tue Feb 16, 2016 5:51 am
My latest
Hennie van Zyl
ZU-IEU Jabiru J170 D
Willie
Unread post by Willie » Tue Feb 16, 2016 7:44 am
Mooi Flooi. Hoe lank het jy hom al? Vertel bietjie van jou ervaring.
ZS-UGS Evans VP 2
ZU-EJD Thorp T-18
Jabiru J400 ZU-VHB
Partenavia ZU-FZS
Flooi
Has liked: 24 times
Unread post by Flooi » Tue Feb 16, 2016 7:59 am
Hallo Willie
Het hom onlangs gekry. Net sowat 3 ure sover gevlieg
330 ure op 912ULS. herbou deur Gideon Niemann. showroom toestand binne en buite.
Baie soos Savannah. Klim beter as Savannah, maar stadiger top spoed agv die slats. Ek het VG's
bestel en gaan die slats afhaal. Kajuit bietjie kleiner as Savannah, maar bagasieruim is groter.
Omdat vlerk kleiner is, voel hy bietjie meer stabiel in turbulensie as Savannah.
Gebruik net 50 met runway. Ek dink die 701 is uitstaande waarde vir geld! =D>
hennie
Hennie van Zyl
Flooi
Has liked: 24 times
Unread post by Flooi » Fri May 06, 2016 3:52 pm
Better with biiig tyres☺
Hennie van Zyl
Flooi
Has liked: 24 times
Unread post by Flooi » Fri May 06, 2016 4:20 pm
Midget EFIS
Hennie van Zyl
Whizzwheel
Flaps set for Take off
Closest Airfield: Pvt
Unread post by Whizzwheel » Thu Jun 02, 2016 2:05 pm
Beautiful airplane! If you put bigger tyres on do you have to raise the nosewheel?
Flooi
Has liked: 24 times
Unread post by Flooi » Thu Jun 02, 2016 4:22 pm
Whizzwheel wrote:Beautiful airplane! If you put bigger tyres on do you have to raise the nosewheel?
Nope. Handles well like this :D
Hennie van Zyl
Whizzwheel
Unread post by Whizzwheel » Thu Jun 02, 2016 4:30 pm
Nice! :D
Pieter Roux
Closest Airfield: FAWA
Unread post by Pieter Roux » Thu Jun 02, 2016 7:07 pm
Hennie Hallo
Van Waar vlieg jy of se maar where are you based
Groete
Pieter (0833775227)
Flooi
Has liked: 24 times
Unread post by Flooi » Thu Jun 02, 2016 7:14 pm
Pieter Roux wrote:Hennie Hallo
Groete
Pieter (0833775227)
Pieter. Teenaan Nigel is die Fincham Runway, net suid van die dorp. Net 2 hangars.
Mooi 600 met runway. Jy's welkom om te kom hello se.
Hennie
Hennie van Zyl
Pieter Roux
Unread post by Pieter Roux » Thu Jun 02, 2016 7:23 pm
Stuur jou Sel nommer
Take care
Pieter
Flooi
Has liked: 24 times
Unread post by Flooi » Fri Jun 03, 2016 1:23 pm
Pieter Roux wrote:Stuur jou Sel nommer
Take care
Pieter
082 419 8998
saterdae en sondae nie beskikbaar, maar elke weeksdag kantoorure kontak enige tyd.
hennie
Hennie van Zyl
Return to “Zenith and Zenair”
