Issues browsing AVCOM on MacBook
Tips and Tricks to get the most out of your AvCom experience.
Wingnutter
Has liked: 16 times
Been liked: 31 times
Unread post by Wingnutter » Sun Mar 31, 2019 5:58 pm
I have brought this up before but with no satisfactory answers or resolution:
If I browse AVCOM on my MacBook it is a horrible, jerky experience - at times the site is virtually unusable. This only occurs on AVCOM and none of the hundreds of other websites I browse. It also only happens on my Mac - no problem on iPad. I have tried checking this out by browsing AVCOM on various devices in a computer retail store - same story on all the latest generation MacBooks, worse for lower spec, but no issues on any of the other PCs or tablets using the same connection. Any idea what is causing and this and why it is particular only to AVCOM - the issue started occurring after the website was updated a few years back.
Jacko
Priming
Re: Issues browsing AVCOM on MacBook
Unread post by Jacko » Sun Mar 31, 2019 6:10 pm
use the Firefox Browers... no issues.
Ball in the middle
Wingnutter
Has liked: 16 times
Unread post by Wingnutter » Sun Mar 31, 2019 6:18 pm
Havent tried Firefox but problem is the same with Chrome. Why only AVCOM - surely this is an issue that can be fixed?
Wingnutter
Has liked: 16 times
Unread post by Wingnutter » Sun Mar 31, 2019 6:30 pm
Tried Firefox and it works fine, but the issues browsing with Safari and Chrome remain.
Has liked: 323 times
Been liked: 352 times
Unread post by jimdavis » Sun Mar 31, 2019 8:26 pm
I use a MacBook Air and Avcom works fine with Safari. Are you using OS Mojave? That, and the previous OS are also fine.
Roger
Closest Airfield: FAPE
Has liked: 52 times
Been liked: 163 times
Unread post by Roger » Mon Apr 01, 2019 7:53 am
There has been some indication that it may be our fixed background causing the issue and may well be a fix. To test that theory please see if issue disappears on our test site at https://avcom.org/phpBB3/index.php
We have disabled the background there at present.
These users liked the author Roger for the post (total 2):
jimdavisWingnutter
Has liked: 106 times
Been liked: 94 times
Unread post by Bell 407 » Mon Apr 01, 2019 8:34 am
Roger, just tested on my MacBook and the terrible scrolling issue has gone away when using the test site. Significant improvement in fact.
So maybe therein lies the solution :wink:
If you do away with the background image, just make it a solid colour to differentiate the outline of the forum.
Unread post by jimdavis » Mon Apr 01, 2019 9:46 am
Okay Roger, I have just tested it on my MacBook Air, and the scrolling is much smoother on the test site. :D
Roger
Has liked: 52 times
Unread post by Roger » Mon Apr 01, 2019 10:34 am
Can you test on https://avcom.org/phpBB3/ again and let me know. Have made an adjustment.
Unread post by Bell 407 » Mon Apr 01, 2019 10:45 am
Still scrolling fine :D :D :D
Roger
Has liked: 52 times
Unread post by Roger » Mon Apr 01, 2019 11:02 am
Have made the changes here on the live site now too. Has it improved?
Unread post by Bell 407 » Mon Apr 01, 2019 11:41 am
From my perspective, yes it has. Thank you. What change did you effect?
Roger
Has liked: 52 times
Unread post by Roger » Mon Apr 01, 2019 11:58 am
Replaced the css for the background image. The main culprit was the background-attachment: fixed; property which seems to cause issues with webkit based browsers.
Unread post by jimdavis » Mon Apr 01, 2019 12:20 pm
Thanks Roger - smooth as silk now! :D
Roger
Has liked: 52 times
Unread post by Roger » Mon Apr 01, 2019 12:46 pm
Must say thank you to Darren. He identified the issue. I did the easy bit.
Return to “Using the Forum - Tips & Tricks”
