PET AND PNR CALCULATIONS
Captain.huzaifa
Forgot to remove the chocks!
Unread post by Captain.huzaifa » Fri Apr 21, 2017 11:41 am
Hi guys
Need some help here with a complex PET/PNR calculation
The question states as follows"
Given:
Ground speed out 320knots
Ground speed home 400knots
Total Distance is 800NM
PET distance is 425NM
Safe distance is 02 hours 55 minutes
WHAT IS THE TIME TO THE PNT?
OR ALTERNATIVELY
Given:
WHAT IS THE DISTANCE TO THE PNR?
Could someone please help?
Much appreciated
Huzaifa
PLAOS7
Fuelling up
Re: PET AND PNR CALCULATIONS
Unread post by PLAOS7 » Tue Apr 25, 2017 8:34 am
Hi Huzaifa,
Given:
In relation to the above I presume they are asking PET?
The formula goes as follows;
PET(in NM) = (Total distance x Groundspeed Home) / (Groundspeed Home + Groundspeed Out)
PET = (800 x 400) / (400 + 320)
PET = 444nm
You then take the above answer and factor it into the Speed = Distance / Time...320 = 444 / ? therefore your time to the PET is 1.39hrs
Given:
PNR(in time) = (Endurance x Groundspeed Home) / (Groundspeed Home + Groundspeed Out)
PNR = (2.92 x 400) / (400 + 320)
PNR = 1.62hrs
You then take the above answer and factor it into the Speed = Distance / Time...320 = ? / 1.62 therefore your PNR distance is 518nm.
:!: You must remeber that the PET formula gives you a distance because you are using a distance in the formula :!:
:!: You must also remeber that the PNR formula gives you a time because you are using a time in the formula :!:
I hope this helps!!
Regards,
PLAOS7
Captain.huzaifa
Unread post by Captain.huzaifa » Tue Apr 25, 2017 10:08 am
Thanks alot buddy
Appreciate it
Captain.huzaifa
Unread post by Captain.huzaifa » Thu Apr 27, 2017 5:45 am
Howsit guys
Here goes another one
Assuming TAS and wind components are standard
Total distance 706nm
Distance to PNR 397nm
Endurance 02 hours 55minitues
What is the Time to the PNR?
There did not give TAS or ground speeds or any wind directions
GeorgeB
Mags On
Closest Airfield: Fisantekraal Airfield
Unread post by GeorgeB » Mon Aug 27, 2018 9:13 am
Howsit guys
This is a case of using percentage it seems.
Calculate a percentage of the trip to PET. (100/706) x 397nm = 56.23% Or 0.5623
So endurance of 2hr 55min x 0.5623 = 98.4 mins which is the answer we believe.
SAAFNAV
Closest Airfield: FAWK
Unread post by SAAFNAV » Mon Dec 03, 2018 4:15 pm
Howsit guys
Here goes another one....
May I please barge in for some help too:
Got this in IR OPS exam.
A-B = 1 200. PET = 60% of total distance, PNR = 84% of total distance.
What is GS from PNR to A. (i.e. GS back). End = 8.24hrs. TAS, wind etc stays constant.
Thanks,
Erich
