NTCA IFR (Again?)
Closest Airfield: FASY
Has liked: 159 times
Been liked: 61 times
NTCA IFR (Again?)
Unread post by Mrb13676 » Thu Aug 09, 2018 6:53 pm
Guys, I’m really struggling to make sense of the CAA’s position on IMC ATF in NTCA.
Is my understanding correct that
1) should I buy a NTCA (eg a Sling) second hand the ATF immediately becomes invalid and must be re-applied for?
2) the CAA will only issue an IF ATF to a pilot/owner who has already got an Instrument rating?
3) if 2 is correct, then I assume that buying a Sling with the view to obtaining my instrument rating on it(obviously with the IFR training with an appropriately qualified instructor aboard) would be a fruitless exercise and I’d be better off with an IF equipped TCA?
Mike.
Mike Blackburn
ZU-IBM - Sling4 Turbo s/n 009
Induna
Closest Airfield: FASD
Has liked: 22 times
Been liked: 26 times
Re: NTCA IFR (Again?)
Unread post by Induna » Thu Aug 09, 2018 7:01 pm
as I have it:
1. If IFR ATF is required then all the instrumentation needs to be TSO'd, installed by a certified AMO and maintained by a certified AMO.
2. The ATF is for the aircraft, not the pilot...
It would be interesting to hear from others.
Jacques van der Westhuizen
ZS-WSW | Sonerai 2L
