Vacancy: Responsible Person Aircraft
Positions in the Administrative, Operational, Engineering or any other aviation support field.
Forum rules
Lisanne
Closest Airfield: ORT
Unread post by Lisanne » Thu Jul 04, 2019 2:47 pm
Solenta Aviation has the following position available: Responsible Person Aircraft based in Fourways, South Africa.
The requirements for this position are as follow:
• At least 10 years post qualified Aviation experience of which 5 years are in Maintenance Management or equivalent.
• Must qualify for the position as per the SA CARS requirements.
• Must be approved by the Licensing Council for this position.
• Excellent interpersonal, communications, public speaking and strategic planning.
• Solid working knowledge of maintenance planning and Continued Airworthiness.
• Solid knowledge of SA CATS and CARS (Parts 43, 66, 91,121,135,145 etc.)
• Solid knowledge of Part 145 Organizations.
• Ability to generate respect and trust from staff and external parties.
• Good knowledge of national aviation regulations
• Solid knowledge and understanding of technical issues and needs.
• Strong operational and project management.
• Demonstrated team player.
• Computer literacy (Excel, Word, PowerPoint, Maintenance tracking system).
• Have excellent planning, organizing and time management skills – prioritize, allocate & delegate.
• Passionate, optimistic and energetic.
• Is able to remain flexible, function under pressure and maintain a positive attitude and work performance in a variety of circumstances.
• Is self-motivated, takes responsibility and has a sense of pride in their work.
• Have a situational awareness.
• Available to travel.
Should you be interested in applying, please contact Lisanne van Wyk (lisanne.vanwyk@solenta.com)
Thank you
Return to “Administration, Operations, Engineering and Other Support”
