BO105 Engineer
Positions in the Administrative, Operational, Engineering or any other aviation support field.
Forum rules
Stephen Robertson
Been liked: 10 times
BO105 Engineer
Unread post by Stephen Robertson » Mon Jul 08, 2019 8:50 pm
Good day,
We are looking for a qualified, type rated BO105 engineer. The machines that we operate are both LS and CBS models.
Please forward your CV through to the following contact:
brandon@flightshare.co.za
Regards,
Stephen Robertson
Flightshare
If you are depressed, you are living in the past.
If you are anxious, you are living in the future.
If you are at peace, you are living in the present.
- Lao Tzu
Return to “Administration, Operations, Engineering and Other Support”
