Vacancy: LAME - AW139 type rated
Positions in the Administrative, Operational, Engineering or any other aviation support field.
Forum rules
Titan Helicopters
Closest Airfield: George Airport
Unread post by Titan Helicopters » Thu Jul 18, 2019 12:25 pm
Indwe Aviation (Pty) Ltd, a leading Aviation company in GEORGE is offering an exciting career opportunity for the following:
Licenced Aircraft Maintenance Engineer AW139 rated:
Minimum Requirements:
• Type rating – AW139
• Valid AME Licence – with all privileges (CAT A &C)
• Grade 12/Matric
• NTC 3 Certificate
• Computer literate
• Valid code 8/B driver’s license (no endorsements)
• Firefighting and safety
• Dangerous Goods
• Sound knowledge of relevant civil aviation legislation, rules and regulations
• Knowledge of aviation equipment and aircraft
• Aircraft Trade Test
• SACAA approved aircraft technical training courses
• Language proficiency level 6 (English)
• Reliable and punctual and able to adhere to strict deadlines
• Excellent ability to function well in a high-pressure environment
• We are a dynamic team and need a person who can fit in and be a team player
Role Purpose and Summary of Tasks:
Ensure that all engineering maintenance activities undertaken are carried out in accordance with the applicable requirements of the relevant civil aviation authorities and as stipulated in the approved Manual Of Procedures (MOP).
Responsible to ensure that all maintenance performed are in accordance with relevant aviation regulations and legislation. Responsible for accurate records to be kept of all maintenance performed on aircraft.
THG is an equal opportunity employer and is guided by the principles of Employment Equity to fair treatment in employment through the elimination of unfair discrimination and practices.
If you meet the above requirements please email a comprehensive CV, with valid references to: hr@thghelicopters.com
If you have not received a response within 14 days please consider your application unsuccessful.
Return to “Administration, Operations, Engineering and Other Support”
