B1900 A&C licenced Engineer vacancy
Positions in the Administrative, Operational, Engineering or any other aviation support field.
Forum rules
Lisanne
Closest Airfield: ORT
Unread post by Lisanne » Fri Aug 02, 2019 2:53 pm
Good day,
Solenta Aviation has a B1900 A&C Aircraft Maintenance Engineer (LICENCED) position available.
The Roles will include the following:
• Carry out all scheduled maintenance - in accordance with the work pack provided and verify availability of spares.
• Carry out unscheduled maintenance, including fault finding/rectification and compiling spares list as required during inspection.
• Plan and delegate tasks. Supervise mechanics, trainees and workshop assistants to ensure high levels of productivity and quality.
• Sign task on completion including defect sheets, work packs and flight folios.
• Sign all other relevant documents before next flight.
• To act as mentor to the team allocated to him and sign all their relevant training documents as the training officer.
• Ensure communication w.r.t. progress, team members and unplanned tasks/situations to Manager.
• Initiate dual inspections as per MOP.
• Ensure each workstation carries only aircraft specific documentation.
• Responsible for the safety and cleaning of the allocated area.
• Ensuring correct store procedures are followed and documentation completed.
• MOP familiarization.
• Supervise 3rd party maintenance and documentation.
• Signing of the Certificate of release to service.
• Brief Pilot before flight after maintenance by your team and accompany the Pilot with his walk-around.
• Fault finding and defect rectification.
If you are interested and qualify for this position, please contact Lisanne van Wyk (lisanne.vanwyk@solenta.com)
Return to “Administration, Operations, Engineering and Other Support”
