Air-Tec Avionics Engineer
Positions in the Administrative, Operational, Engineering or any other aviation support field.
Forum rules
Lize
Closest Airfield: ORT
Unread post by Lize » Fri Aug 30, 2019 12:33 pm
Job Vacancy – Avionics Engineer
Air-Tec is seeking suitable candidates to fill the role of Avionics Engineer, reporting to the Accountable Manager Maintenance, based in Bethlehem.
Suitable candidates must be willing to travel and have a valid passport
Job Title
Avionics Engineer - reporting to the Accountable Manager Maintenance
Job purpose
  • Perform pre-flight, transit and arrival checks
    Line maintenance
    Conduct inspections and troubleshooting
    Fault finding and rectification
    Perform A-checks including weekly service checks.
Knowledge, skills and experience required
  • Grade 12
    Good knowledge and understanding of a computer
    Valid South-African passport holder
    SACAA W or W & X License
    Sound understanding of technical aircraft publications and documentation
    Willingness to work shifts, weekends and on public holidays
    Must be available and willing to travel at short notice, both locally and internationally.
Professional Experience:
  • 3 Years' experience on type as a licensed AME, or 3 years' experience on a similar type 1900 or Let
Skills
  • Detailed and able to work under pressure
    Able to follow instructions
    Committed to delivering quality work
    Proactive self-starter capable to function on his/her own without any supervision
    Good team player
Should you have the necessary skills and requirements to fill the position please send you CV to lize.misic@air-tecm.com. Preference will be given to applicants of designated EE groups.
Return to “Administration, Operations, Engineering and Other Support”
