VP1 in progress
The Evans VP-1 Volksplane is an American designed aircraft for amateur construction designed by aeronautical engineer William Evans
P Pilot
Post Take off checks
Re: VP1 in progress
Unread post by P Pilot » Thu Nov 02, 2017 11:25 am
Progress!
She held her wings for the first time on her own yesterday. The struts are coming along nicely. Once they're all completed, wings will be ready for covering.
Cedric Snr
Re: VP1 in progress
Unread post by Cedric Snr » Thu Nov 02, 2017 1:06 pm
Thats good progress there Pat. keep up the good work.
Cedric Strydom
0763157134
cedric.strydom@live.co.za
bosvark
Closest Airfield: Rhinopark
Has liked: 19 times
Been liked: 11 times
Re: VP1 in progress
Unread post by bosvark » Fri Dec 08, 2017 12:34 pm
P Pilot, wings covered yet?
P Pilot
Re: VP1 in progress
Unread post by P Pilot » Fri Dec 08, 2017 12:46 pm
Sadly not yet.
Got some final work done on the struts, and will just need to check them out and then it's final prepping for a clear coat and then covering.
I'm hoping to get them across to the guy to be covered over December...
P Pilot
Re: VP1 in progress
Unread post by P Pilot » Sun Jan 28, 2018 7:45 pm
Wings are on their way for some covering!
Now I can get going on the fuselage...
P Pilot
Re: VP1 in progress
Unread post by P Pilot » Tue Feb 06, 2018 6:05 pm
Covering is going great so far!
Jean Crous
Closest Airfield: FASX
Has liked: 147 times
Been liked: 67 times
Re: VP1 in progress
Unread post by Jean Crous » Tue Feb 06, 2018 8:26 pm
Mr P Pilot , that is looking very enterprising to say the least :lol: May you soon be done and start enjoying the bird in flight. :wink:
Jean
Cubby Aircraft Factory
Cell : 072 6716 240
P Pilot
Re: VP1 in progress
Unread post by P Pilot » Wed Feb 14, 2018 6:04 am
Two steps forward and one step back...
I discovered the aluminium tube that forms the spar and pivot of the rudder was incorrect. The wall thickness was 0.049" instead of 0.058". It probably would've been okay, but thought the best option was to replace it with the correct part per the plans.
It turned out not to be such a big job. Quite a bit of cutting to get it out, but it's out and the new one should be arriving this week. The rudder will need to be recovered though. Putting it all back together will be the interesting/scary part.
I will be much happier having the correct tube installed. I think it was the right way to go.
Progress!
P Pilot
Re: VP1 in progress
Unread post by P Pilot » Sun Mar 18, 2018 1:40 pm
Wings are covered!
Also making good progress with the rudder. I've changed the ali tube for the correct part. Just need to finish up some work in the rudder - with some help and expertise from Gav the Great, then it'll be ready for recovering.
I've also stripped the covering off the tailplane to double check everything inside and it all looks good, so that'll also be off for covering soon.
Next is to get the wings on and do an initial weight and balance to see where I need to mount the engine. I'm expecting to move it forward to prevent a tail heavy VP, so will have to make a mount accordingly.
Cedric Snr
Re: VP1 in progress
Unread post by Cedric Snr » Mon Mar 19, 2018 5:58 pm
I've seen the pictures on WhatsApp, but they look even better when viewed on the big monitor from my computer. Nicely done Patrick.
Cedric Strydom
0763157134
P Pilot
Re: VP1 in progress
Unread post by P Pilot » Sun Apr 22, 2018 7:34 am
It was weigh day this week...
And everything came out very nicely! First time I've had the covered wings on as well. I wanted to weigh her all together to check where we stand with empty weight (minus engine) and I wanted to check CG. I need to start looking at the engine mount and this will give me an idea of where to put the engine to avoid adding weight to correct the CG. I've heard that VPs are notoriously tail heavy. Now just to figure out the CG of the engine and then I can send the figures off to some clever people to do the calcs.
I must say that having her all together like that makes it all look like it's getting closer! Getting excited!
FLYGUYS
Re: VP1 in progress
Unread post by FLYGUYS » Sun Apr 22, 2018 11:11 am
Looking good Pat, almost time to fly :D :D
Ready for Nylstroom ???
ZU-ANG
Jean Crous
Re: VP1 in progress
Unread post by Jean Crous » Sun Apr 29, 2018 4:22 pm
Hi Patric , do you have an engine for her ?
Jean.
Cell : 072 6716 240
P Pilot
Re: VP1 in progress
Unread post by P Pilot » Sun Apr 29, 2018 6:10 pm
Hi Jean,
I do! It's a HAPI converted 1835 VW. It came out of a Quickie apparently...
P Pilot
Re: VP1 in progress
Unread post by P Pilot » Sat Mar 30, 2019 6:31 am
Some progress photos from the past few months. Getting there slowly!
Return to “Evans Volksplane”
