Evans Volksplane VP1
The Evans VP-1 Volksplane is an American designed aircraft for amateur construction designed by aeronautical engineer William Evans
bosvark
Closest Airfield: Rhinopark
Has liked: 19 times
Been liked: 11 times
Re: Evans Volksplane VP1
Unread post by bosvark » Tue Jun 09, 2015 9:45 pm
Hello Jean
Very little, very slowly.
Mounted the starter motor and engine to a dummy firewall, removed the spark plugs and then spun the engine until oil came out the oil cooler pipe. Then connected the pipe and spun it again to pump oil through it.
At least I had an inlet manifold made but when I fetched the engine from the shop, it was leaking oil out where the one push rod tube goes into the engine casing. I am not knowledgeable on these type 1 VW engines, so cannot think how that came about. It has been standing in my garage for long now and made a trip across the country and back without oil leaks. Will probably have to have the cylinder head removed to get it fixed.
Groete
Eddie
tobias
Preflighting
Unread post by tobias » Thu Jul 02, 2015 7:07 pm
Edie,
Lyk my maar stil daar by jou. Dit blyk my dis n algemene tendens. Klink my min manne is voluit besig om te bou nie. Het jy al jou enjine uitgesort?
Tobie
bosvark
Has liked: 19 times
Unread post by bosvark » Sat Jul 04, 2015 8:47 pm
Hallo Tobie, nee nog nie uitgesort nie, maar ek het nog nie regtig aandag aan die issue gegee nie. :oops: :oops:
tobias
Preflighting
Unread post by tobias » Fri Jul 21, 2017 7:12 pm
Hi Eddie
Two years is along time, are you still building at all? You have come so far please do not let you dream die..... I realy looked forward to offer you a hot cuppa on your first X/Country to Thabazimbi and fly in a loose formation wth you..
My VP has gone to a good home and I understand she is slowly making progress to becoming a butterfly....
Hope you will get going soon my friend
Tobie
bosvark
Has liked: 19 times
Unread post by bosvark » Fri Jul 21, 2017 9:44 pm
Ai Tobie :oops: Ek vroetel, vroetel so aan die ding. Busy getting the wings ready for covering. God willing, I will put some time in tomorrow. [-o<
bosvark
Has liked: 19 times
Unread post by bosvark » Wed Feb 14, 2018 9:37 pm
Submitted application yesterday to register my VP.
ZU -VPI 8)
heinrich
Closest Airfield: EGSX
Unread post by heinrich » Wed Feb 14, 2018 10:30 pm
=D> =D> =D>
Cedric Snr
Unread post by Cedric Snr » Thu Feb 15, 2018 6:09 am
Good show Eddie. Now post some pictures so we can see how she looks.
Cedric Strydom
0763157134
cedric.strydom@live.co.za
bosvark
Has liked: 19 times
Unread post by bosvark » Thu Feb 15, 2018 7:41 am
Still looks the same :oops: :oops: Have added "work in progress" behind the reg
Mike Wissing
Closest Airfield: KBDN
Been liked: 86 times
Unread post by Mike Wissing » Mon Feb 19, 2018 5:41 pm
My fuselage and tail plane are complete. I have all the ribs and main spar.
All I have to do is finish it....
Engine needs a tear down and rebuild, and I need wheels and brakes. Not a lot to do comparitively, but I am elbows deep in my Pietenpol project too.
Winter is nearly over, so our long days begin!
Some photos please Eddie!
BTW: I'm covering both projects with Oratex
Mike Wissing
C.A.P. Search and Rescue Mission Pilot - SAR Check Pilot.
Professional RV builder and company test pilot
I can't wait for computer keyboards to come out with a breathalyzer..........
bosvark
Has liked: 19 times
Unread post by bosvark » Mon Feb 19, 2018 9:33 pm
I can't get my photos to fit. keeps saying the file is too big. Or something to that effect.
Johan Swakopmund
Returning to aircraft
Closest Airfield: Swakopmund
Has liked: 32 times
Been liked: 30 times
Unread post by Johan Swakopmund » Tue Aug 21, 2018 11:56 am
Bosvark
Los die land rovers uit en maak die Volksplane klaar
Ek kom so Sept rond bobbejaansberg toe om kinders te kuier en wil inspeksie
kom doen - en ontmoet - op jou VP en Cedric sin wat hy by my gekry het.
groete uit die woestyn
Johan de Wet
NAMIBIA FLYING COUNTRY
bosvark
Has liked: 19 times
Unread post by bosvark » Mon Aug 27, 2018 1:06 pm
Bosvark
Johan de Wet
Die LR is verkoop. Maar ek dink hy is nou in sy m@&r! #-o #-o
Dit sal gaaf wees! 083 296 4699
bosvark
Has liked: 19 times
Unread post by bosvark » Fri Oct 05, 2018 9:13 am
Some photo's taken a while back:
bosvark
Has liked: 19 times
Unread post by bosvark » Fri Oct 05, 2018 9:15 am
Have one wing now covered. Must still install inspection rings, tapes and do the doping etc:
Return to “Evans Volksplane”
