Speeds
EFT
Closest Airfield: VIRGINIA
Speeds
Unread post by EFT » Wed Apr 17, 2013 10:41 am
What does no ATC speeds mean? Can you disregard the TMA speeds, the SLPs on a STAR as well as the airspace limit of 250 kts below 10000ft, or which are included/excluded?
Thndr_strck
Re: Speeds
Unread post by Thndr_strck » Wed Apr 17, 2013 9:00 pm
All of the above
When in doubt...DON'T !!
Breytiesj
Re: Speeds
Unread post by Breytiesj » Tue Apr 23, 2013 10:49 pm
Kind of common sense....
Alnahas
Closest Airfield: Jeddah
Re: Speeds
Unread post by Alnahas » Sun Jul 16, 2017 12:00 am
Star and Sid can be cancel by act but 250 below 10000 can't be exceeded
happyskipper
Closest Airfield: FQNC
Re: Speeds
Unread post by happyskipper » Sun Jul 16, 2017 1:39 pm
Alnahas wrote:Star and Sid can be cancel by act but 250 below 10000 can't be exceeded
That sounds more accurate.
Mark 8)
DavidPilot1
Re: Speeds
Unread post by DavidPilot1 » Fri Aug 18, 2017 4:42 am
Aircraft speed
91.06.9 (1) Unless otherwise authorised by the Director, no person shall, outside controlled airspace and below flight level 100, fly an aircraft at an indicated air speed of more than 250 knots.
(2) Unless otherwise authorised or required by an ATSU, no person shall fly an aircraft within a control zone or an aerodrome traffic zone at an indicated air speed of more than—
(a)
160 knots, in the case of a reciprocating-engine aircraft; or
(b)
200 knots, in the case of a turbine-powered aircraft:
Provided that if the minimum safe indicated air speed for a particular flight is greater than the maximum indicated air speed prescribed in this regulation, the aircraft may be flown at the minimum safe indicated air speed.
Aquila
Re: Speeds
Unread post by Aquila » Sat Dec 23, 2017 12:10 am
Some countries do allow speeds in excess of 250 kts below 10 000' so if in doubt, confirm with the ATC...
Raccoon jet driver...
See Horizons!
Has liked: 461 times
Been liked: 108 times
Re: Speeds
Unread post by ACE MAN » Sat Dec 23, 2017 1:23 am
The max 250 below 10 is also cancelled when ATC give you no speed restirctions, your company policy however may not allow it.
eDIT , just to be clear I am talking purely wrt SA ATC, the states for e.g. Cannot cancel that speed.
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
AOYB
Re: Speeds
Unread post by AOYB » Wed Jan 17, 2018 12:40 pm
As an English pedantic, the phrase “outside controlled airspace and below FL100” should read “outside controlled airspace OR below FL100” if you want to stop people going faster than 250kts.
The law as it stands means you can go faster than 250 below FL100 if ATC has cancelled the STAR OR SID speeds (and obviously inside controlled airspace)
I am the last Cylon...
Return to “ATNS”
