SA's VHF Repeaters
Segg
Has liked: 117 times
Been liked: 25 times
SA's VHF Repeaters
Unread post by Segg » Mon Mar 05, 2018 7:31 pm
Hi Guys
Does anyone have a list of the physical locations of South Africa's VHF repeater stations, and their altitudes?
The reason I ask this is after experiencing poor VHF reception in some areas, and speaking to others who have experienced the same issues in the same places, we contacted ATNS to report the issues and got the response that these are uncommon events, when clearly they are not. These issues were experienced in different aircraft, with different (but modern, and in one case new) avionics in the same general areas on different dates
Knowing where these stations are will make planning a little easier, as it's really not the nicest thing being told to report a point, then not being able to get through to the controller :? One individual was even asked to report to the tower on landing after not being able to contact JNB East before entering Durban Special Rules [-X
Has liked: 461 times
Been liked: 108 times
Re: SA's VHF Repeaters
Unread post by ACE MAN » Mon Mar 05, 2018 7:39 pm
Hi Segg, AFAIK the whole country should be covered FL110 and above via repeaters. Unfortunately our (NTCA/light a/c) transmitter strength/aerial capability is often at fault. ATC should have clear enough comms with us within say 50nm of their receivers at any height subject to obvious obstructions/terrain.
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
ppakotze
Unread post by ppakotze » Wed Mar 07, 2018 11:02 am
Most likely co-located with other ATNS navigation beacons such as VORs etc.
P.
MemyselfandI
Unread post by MemyselfandI » Tue Mar 27, 2018 8:00 am
There used be one at Victoria West and one at Ulco....no idea if that's still the case.
Return to “ATNS”
