Recomended VFR routes?
StuartA
Closest Airfield: Pietermaritzburg
Unread post by StuartA » Tue Jul 01, 2008 12:45 pm
Can anyone tell me where can I download a complete list of recommended VFR routes for SA?
Thanks.
Stuart
cvh:.
Unread post by cvh:. » Tue Jul 01, 2008 2:12 pm
What? there are VFR routes?
Thought they faded out with "Smith's Pilots Aids"
3015
Re: Recomended VFR routes?
Unread post by 3015 » Tue Jul 01, 2008 2:35 pm
Hi Stuart
There are not really recommended VFR routes published for SA. Best is to ask for info from local pilots in the area that you want to visit. AFAIK the only VFR recommended routes are found in the Jeppesen VFR charts that can be bought from any pilot shop. Hope you come right.
StuartA
Unread post by StuartA » Tue Jul 01, 2008 2:53 pm
Thanks. The Pilot's Radio Handbook lists some of them and EasyPlan also shows some. I was hoping there was standard list available somewhere, maybe on the ATNS site. No prob - will just revert to using common sense (if I can track some down).
Stuart
The quiet man
Preflighting
Unread post by The quiet man » Tue Jul 01, 2008 10:07 pm
Also check on the AIP as there are mandatory VFR routings below some TMAs. The idea is to keep VFR traffic clear of the controlled airspace.
126.7
Unread post by 126.7 » Wed Jul 02, 2008 9:36 pm
There are what are referred to as Special Rules areas, which normally have published VFR routes to keep the traffic on a desired flight path. I know FAPE, FADN (Greytown Special Rules) and the FAJS TMA have special rules area. I have not worked in FACT so cannot speak for them...
These would all be published in the AIP.
Walid
Unread post by Walid » Sun Feb 02, 2014 4:33 pm
What I found after some digging.
Return to “ATNS”
