Here we go again - RV10 build
ibeaton
Rolling from unmanned
Closest Airfield: Tedderfield
Unread post by ibeaton » Sat Jul 04, 2015 5:13 pm
Well the itch returned, and I started to scratch.
So with an empennage kit safely tucked away in the workshop work begins again. Amazingly familiar this time around.
Well that is it for the first instalment.
Build on.
Ian
Vans RV7 ZU-FSG complete.
RV10 QB is under way
Empennage complete
Tail cone complete
Fuselage largely complete
Electrical and avionics largely complete
Finishing kit largely complete
On to firewall forward
Jan
Closest Airfield: COVES
Re: Here we go again - RV10 build
Unread post by Jan » Mon Jul 06, 2015 6:33 am
Now you are doomed :lol: :lol:
Watch out - I am busy with #6 and cannot stop :oops:
Well if you need any advise you at least know where to go.
Flying is about discipline!
AP325
Has liked: 331 times
Been liked: 75 times
Unread post by ACE MAN » Mon Jul 06, 2015 7:25 am
Nice Ian, is andrew working with you again. Awesome project
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
hoz
Closest Airfield: fala
Unread post by hoz » Mon Jul 06, 2015 4:12 pm
Ian, thanks for the tour of the workshop yesterday. I am suffering from an RV grin without even going in the air! :D
Ryan Beeton
Unread post by Ryan Beeton » Tue Aug 04, 2015 8:33 am
Holy Crap! Big project Ian. :shock: :shock: :shock: :shock:
Got a nice clean hangar with tool store room for you to build in.
Carpe Diem
RSH2
Closest Airfield: Jack Taylor
Unread post by RSH2 » Thu Aug 13, 2015 8:19 am
Fantastic !!!! =D>
ibeaton
Unread post by ibeaton » Mon Aug 31, 2015 1:44 am
So real work has got in the way a bit, also been flying the Seven, so not much progress to record.
A little bit of Riveting
and here is the result
However here are a few shots of a much improved dimpling mechanism I have developed for doing large skins.
Normally lining the dimple die up with the hole is a pain in the neck, so stuck some LED lights onto the steel bucking board and hey presto, and improvement of 300% in accuracy of finding the dimple die. Simple.
Just shed a little light on the matter and it shines through the drilled hole making it a simple task to line it all up, should work on the DRDT too.
Empennage complete
Tail cone complete
RudiGreyling
Closest Airfield: The Coves
Unread post by RudiGreyling » Wed Sep 02, 2015 10:29 am
Good Luck, looking forward to the build thread!
Amateur Kit Builder
ibeaton
Unread post by ibeaton » Sun Oct 04, 2015 8:06 pm
Little by little it comes together:
Parts prepped and laid out for primer
Mommy not too happy with what is happening in her back yard:
Build on...
Empennage complete
Tail cone complete
Jan
Unread post by Jan » Mon Oct 05, 2015 5:53 am
The VS is OK. But wait until you hit the HS - it is huge copmared to the HS of the 7 :D
AP325
ibeaton
Unread post by ibeaton » Wed Oct 07, 2015 9:33 pm
Jan wrote:The VS is OK. But wait until you hit the HS - it is huge copmared to the HS of the 7 :D
Thanks Jan,
I can see that, the spars are probably as long as the wing of the 7, must say playing with the bits again is rather fun. The manual for the 10 is also a big step forward, a real pleasure to work with.
Vans have really got the process well developed now.
Probably need to pop across and have a cup of coffee and a chat some time.
Ian
Empennage complete
Tail cone complete
minivan
Unread post by minivan » Mon Oct 12, 2015 5:42 pm
Hi Ian
Glad you are on your way again... =D>
I will sit and watch this thread with special interest ..... :(
Enjoy
Pierre
Like all great things achieved in life .... Little inspiration and a lot of perspiration... therefore "Carpe Diem"!!!
RV-10 #41049 - Building Emp Kit
http://www.mykitlog.com/users/index.php ... roject=856
ibeaton
Unread post by ibeaton » Sun Oct 18, 2015 3:54 pm
A few big days with a bunch of parts ready for riveting.
Next a mammoth rivet session and rudder and elevators will be complete.
Ian
Build on....
Empennage complete
Tail cone complete
ppakotze
Unread post by ppakotze » Tue Jan 05, 2016 3:25 pm
Any building over the year end break?
ibeaton
Unread post by ibeaton » Tue Jan 05, 2016 7:10 pm
Yup, quite a bit, have not posted photos too busy flying, but basically vertical stab, rudder, elevators and trim tabs complete except for fiberglass work. Next horizontal stab and then on to tail cone.
Empennage complete
Tail cone complete
