Importing an aircraft
Questions for RAASA
pm.botha
Unread post by pm.botha » Tue Mar 26, 2013 10:47 am
What are the process of importing an aircraft and what costs are add on's when the aircraft arive in SA. If you fly it to SA, how do you get permission to fly a another country's registration number?
Deon lombard
Closest Airfield: Brakpan
Re: Importing an aircraft
Unread post by Deon lombard » Tue Apr 16, 2013 9:54 pm
I have tried it ith the Remos from the USA, and believe me, it was agony o get through all the processes
Firstly you have to ake sure it's type accepted first in SA
Then you ave to make sure you have a FAA and SA CFI to do conversions on it ith the overseas pilot and CAA certification
Then you have to die register it wore you can register it in SA, nd then go through all the motions of test flights and ATF procedures with a SA. Test pilot Good luck
Return to “RAASA”
