GPL to TMG
Questions for RAASA
ajmey52
Preflighting
Closest Airfield: FAPS
GPL to TMG
Unread post by ajmey52 » Sun Nov 08, 2015 5:30 pm
Hi there I was wondering. In order to obtain your TMG license/ rating. What is the needed steps to follow, if you already have you GPL?
J27Alpha
Re: GPL to TMG
Unread post by J27Alpha » Sun Dec 06, 2015 7:02 pm
After great pain and confusion, I managed to get the actual requirements out of RAASA ...
(Note, this might or might not change so confirm with them first) But I finished the rating last week, so this is what worked for me :-) Hope this helps
Note: Up until the day I wrote the exam they didn't know what exam was needed, so expect some confusion... It's a very basic exam ....
Conversion requirements to get a TMG endorsement on a GPL
1. Write a conversion exam at a RAASA approved testing center.
2. Minimum of 10 flights in a TMG
3. Two dual cross country flight with a duration of not less than 90 minutes flown at normal cruising speed, of which at least one will be a navigation test.
4. One solo cross country flight , duration of not less than 90 minutes flown at normal cruising speeding including a full stop landing at point other than the point of departure and destination (with no engine shut down or soaring requirements; and
5. At least one dual and one solo flight into controlled airspace including a full stop landing and take-off at a controlled airfield.
6. The skills test with a Grade A or B TMG instructor
Good Luck !
Jason
ajmey52
Preflighting
Re: GPL to TMG
Unread post by ajmey52 » Mon Dec 21, 2015 2:57 pm
Thank you very much Jason. That helps a lot.
Return to “RAASA”
