Piper PA-28 wing falls off
Spoke Eagle
Been liked: 26 times
Re: Piper PA-28 wing falls off
Unread post by Spoke Eagle » Fri Apr 20, 2018 6:56 am
:shock:
Has liked: 171 times
Been liked: 152 times
Unread post by richard C » Fri Apr 20, 2018 8:26 am
Unreported ground handling incident ?
Grant all equity and dignity.
ddevos
Closest Airfield: FAVV
Been liked: 23 times
Unread post by ddevos » Fri Apr 20, 2018 8:49 am
richard C wrote:Unreported ground handling incident ?
Or a very hard landing followed by inadequate repairs?
Dirk de Vos
Backmarker
FREDA checks
Closest Airfield: Waterkloof
Unread post by Backmarker » Fri Apr 20, 2018 8:56 am
Or Aeros? This aircraft definitely had some abuse or an accident.
Greenie
Has liked: 419 times
Been liked: 478 times
Unread post by jimdavis » Fri Apr 20, 2018 9:51 am
Backmarker wrote:Or Aeros? This aircraft definitely had some abuse or an accident.
Absolutely. My old 140 EKE has done over 20 000 hours. It is not a time thing it is an abuse thing.
Has liked: 29 times
Been liked: 162 times
Unread post by heisan » Fri Apr 20, 2018 10:01 am
The NTSB report is a little more interesting than the newspaper article.
https://app.ntsb.gov/pdfgenerator/Repor ... m&IType=FA
Photo of the fractured spar cap is interesting. To my untrained eye, it looks like quite an old crack originating at the bolt hole, and spreading from there. Would probably have been visible for many MPIs prior to the accident. I wonder if the MPI schedule calls for a visual inspection of this area?
Volo
Has liked: 65 times
Been liked: 100 times
Unread post by Volo » Fri Apr 20, 2018 12:16 pm
heisan wrote:The NTSB report is a little more interesting than the newspaper article.
Exactly that - The striations or series of rings are fatigue related and are clearly generated from the bolt holes . Rough edges from the hole drilling probably produced the original stress raiser . It looks as though the spar was down to below half its original strength when it let go .
I would not be surprised if some sort of inspection will become mandatory regarding this failure .
Unread post by richard C » Fri Apr 20, 2018 12:36 pm
Surely not !
This is a Cherokee, probably millions of accumulated hours in the training environment. Never a wing lost prior, I would guess.
This has to be a specific problem to this particular aircraft, or the ATO in the way they manage their aircraft.
happyskipper
Closest Airfield: FQNC
Unread post by happyskipper » Fri Apr 20, 2018 10:57 pm
Mark 8)
Rotor kop
Closest Airfield: OR Thambo
Has liked: 320 times
Been liked: 30 times
Unread post by Rotor kop » Sat Apr 21, 2018 6:30 am
Looking at that drawing. Only the first pair of bolts are doing the work. Cant believe there are not tons more of these incidents. There is no extra support in that area and according to me there should be. A fine example is to look at Frank Robinsons extra support he does on the tail boom where it joins the hull. Wings that are unsuportedby a strut give me the hibby jibbies :shock: I am sure they are fine as they have been around for ages and have millions of hours but i feel more comfortable in a "built like a tractor" fixed wing.
Rotor kop
Unread post by Rotor kop » Sat Apr 21, 2018 6:34 am
Barros
Closest Airfield: Earls Colne
Unread post by Barros » Sat Apr 21, 2018 8:21 am
This accident may make me think twice next time I climb into a Pa 28
Volo
Has liked: 65 times
Unread post by Volo » Sat Apr 21, 2018 8:43 am
Surprisingly - the Spar root is a crap design . Best design would be a tongue with bolts through the web .
They have put bolts through the Flange which is what takes the load .
happyskipper
Unread post by happyskipper » Sat Apr 21, 2018 9:58 am
flyinghighno2 wrote:This accident may make me think twice next time I climb into a Pa 28
Dead right FH2 - I have always felt safe in cherokees - now, maybe not so much.
My pre-flights are going to be a lot more thorough from now on....
Mark 8)
TOFFS
Closest Airfield: FARS
Unread post by TOFFS » Sat Apr 21, 2018 10:40 am
The PA 28s main spar slots tightly into the fuselage in a spar box and is bolted through the upper and lower spar caps. This is a very strong attachment (as demonstrated by a million hard landings).
Inspection in this area during MPI is difficult compounded by upholsterers taking the easy road and gluing their brand new carpet over the spar box instead of the hassle of putting press studs as Piper intended. As per normal, the lightening holes would never be adjacent the bolts as this would make life to easy. So, pulling the owners brand new carpet off the spar cap, standing on your head with torch and mirror to inspect the spar often gets ignored by some.
In South Africa RSA AD 97-02 has you x-ray in this area every five years. It does take a very well trained eye to pick up cracks or corrosion, even on an x-ray.
From viewing the picture of the affected wing, there is no corrosion seen. There are old cracks that weaken the structure to the point of total failure.
Unfortunately, no pre-flight inspection gains access to where this failure occurred and if this accident makes you scared of flying a Cherokee you had then better be very wary of flying just about any other aircraft and I am not the biggest Piper fan but that wing attachment is as strong as you can possibly make it without any huge weight penalties.
Eric Cook, Accountable Manager, Master Tech Aircraft Maintenance, Robertson, Western Cape
Tel: 083 4130131 Website: https://mastertech.aero Email: mastertech.eric@aol.com
