Piper PA-28 wing falls off
StressMerchant
Closest Airfield: Cab
Has liked: 9 times
Been liked: 87 times
Re: Piper PA-28 wing falls off
Unread post by StressMerchant » Wed May 23, 2018 2:35 pm
I won't argue that the design is poor, and that Piper did not make repair work easy. The presence of structural members that cannot be inspected is a worry.
I have a suspicion that the initiating event for this failure was either at production or a major maintenance episode.
FWIW staggering of bolts is not necessarily the answer. The bolts and rivets need to be at the right place, and under the right loads, to effectively transfer the load through the structure.
- Douglas Adams
RogerRoger
Unread post by RogerRoger » Tue May 29, 2018 8:32 pm
I have no horse in this race but this is interesting :shock:
wear the fox hat.
Has liked: 296 times
Been liked: 222 times
Unread post by Ugly Duckling » Fri Sep 06, 2019 12:42 am
Surge
Closest Airfield: FAWK
Unread post by Surge » Fri Sep 06, 2019 3:17 am
NTSB report
https://www.ntsb.gov/_layouts/ntsb.avia ... 120&akey=1
Sheew! There are some very clever people in this world.
The problem was also discovered on another PA-28R-201 (N104ER) operated by ERAU so this is not a once off problem. It likely saved some lives in the process.
The USAF estimated that the sister airplane's wing, with a fatigue crack measured at 0.18 inch, was less than 2,000 hours from failure.
It doesn't look like a visual inspection would have picked up the problem. Certainly not with the wings in place. :?
The fatigue crack on bolt hole LC-1 on sister aircraft N104ER was not visible using optical magnification.
It was only detected when the the wings were removed and a "level II certified ultrasonic testing inspector" used a HFEC surface probe for testing.
kudu177
Has liked: 51 times
Been liked: 10 times
Unread post by kudu177 » Fri Sep 06, 2019 7:49 am
Volo wrote:
Thu Apr 05, 2018 10:02 am
I seem to remember something about mainspar corrosion being a problem on older PA 28's - would kind of explain the complete detachment of a wing !!
True. About the time i was doing my PPL in George (Dec 1988),a story in one of the US flying mags that we had in the clubhouse about Cherokee 140 main spar failures got everybody’s attention.
Easpecially since the school aircraft had spent a lot of time in a coastal environment.
Nav is a good life lesson: pick a point on the horizon and go there
dollar
Has liked: 50 times
Been liked: 12 times
Unread post by dollar » Fri Sep 06, 2019 10:55 am
Wow. I watched the video and must say that it’s a pretty simple attachment method. And cheap to make I bet. It obviously works though - wings don’t routinely fall off?
So the forward attachment bears most of the load stress. The rear attachment the lateral stress - backwards and forwards. The rear all held together by one bolt?
Looks like it’s operating close to its limits - bit of undetected fatigue or damage and bye bye wing.
ddevos
Closest Airfield: FAVV
Been liked: 17 times
Unread post by ddevos » Fri Sep 06, 2019 4:11 pm
Even Impala jets have one bolt holding the rear spar. I once had the unenviable task of cutting a rear spar off with a hacksaw because the bolt was bent inside the joint and we just couldn't get it out where the aircraft was lying on its belly in soft sand. That was in 49 degrees of heat as well! Not fun...
These users liked the author ddevos for the post:
dollar
Dirk de Vos
Has liked: 28 times
Been liked: 140 times
Unread post by heisan » Sat Sep 07, 2019 1:02 am
Every single part of every aircraft is operating close to its limits (usually only 1.5x safety margin). Could build them stronger, but then they would be too heavy to fly ;).
These users liked the author heisan for the post (total 2):
dollarjimdavis
