Taildraggerdriver
Changing Underwear
Closest Airfield: faps
Has liked: 32 times
Been liked: 16 times
Unread post by Taildraggerdriver » Fri Jun 21, 2019 8:32 am
richard C wrote:
Wed Jun 19, 2019 9:57 am
Wow, where are they going to park them all ?
Boeing’s don’t park, they fly 8)
C210
Cirrus sailplane
Has liked: 313 times
Been liked: 236 times
Unread post by Ugly Duckling » Fri Jun 21, 2019 8:51 am
Must be waiting at the drive-thru then :twisted:
These users liked the author Ugly Duckling for the post:
Mfezi
Has liked: 329 times
Been liked: 357 times
Unread post by jimdavis » Fri Jun 21, 2019 8:58 am
Paulus, I hope I don't have to remind you again about wandering off topic. [-X [-X [-X [-X
MODS :roll:
Has liked: 132 times
Been liked: 131 times
Unread post by richard C » Fri Jun 21, 2019 9:19 am
sowwy 8-[
Grant all equity and dignity.
MadMacs
Closest Airfield: GRJ
Has liked: 268 times
Been liked: 48 times
Unread post by MadMacs » Thu Jun 27, 2019 9:40 am
I'm not old, I'm 18 with 46 years of experience :D
Volo
Has liked: 40 times
Been liked: 71 times
Unread post by Volo » Thu Jun 27, 2019 11:19 am
:oops: FAA find more problems
https://www.npr.org/2019/06/26/73643041 ... -to-flight
Bizarre to say the least - the FAA issue a statement that they have found a new problem but don't tell you what it is .
sweptwing
Has liked: 29 times
Been liked: 13 times
Unread post by sweptwing » Thu Jun 27, 2019 1:11 pm
They have probably figured out that a normal trim runaway is more dangerous then a false MCAS input.
Personally I think the only way to sort this out for good, is with high quality pilot training. Crew need to be able to recognize the trim runaway and act with the memory items without delay.
I know there's a lot of money in aviation because I put it there.
Has liked: 28 times
Been liked: 143 times
Unread post by heisan » Thu Jun 27, 2019 1:14 pm
Well, the FAA will generally not tell the public what the issue is - it is for Boeing to publish it. Some details have been leaked though:
https://edition.cnn.com/2019/06/26/poli ... index.html
It has nothing to do with MCAS itself - but rather a failure of the computer on which MCAS runs (also a lot of other trim control software runs on this computer). If the computer fails, then it can leave the trim running - a classic 'trim runaway' scenario. The FAA has previously stated (look back a page or so on this thread) that they are not happy with Boeing's (and probably the rest of the industry's) method of determining if a pilot can safely recover from a trim runaway - so now every trim runaway path is being evaluated.
Significantly, this is a shared system with the NG. It will be a real disaster if the FAA decides that the NGs should be grounded too...
MadMacs
Unread post by MadMacs » Fri Jun 28, 2019 9:18 am
The problem that the FAA are encountering is not a failure of the computer as falsely reported but rather the response time of the system to react to the input from the yoke trim switches. Why they are only finding this now beggars belief.
MadMacs
Unread post by MadMacs » Sun Jun 30, 2019 12:22 pm
bucky_za
Engine Cranking
Closest Airfield: rand
Has liked: 16 times
Unread post by bucky_za » Mon Jul 01, 2019 4:31 pm
In the old days, bean counters worked around what the engineers wanted,
Now the engineers work around what the bean counters want it would seem.
These users liked the author bucky_za for the post (total 2):
jimdavistansg
Unread post by jimdavis » Mon Jul 01, 2019 7:23 pm
Very neatly put, Bucky. =D> =D> =D>
John.com
Closest Airfield: Aeroden
Has liked: 16 times
Unread post by John.com » Sun Jul 07, 2019 12:24 pm
I found this outstanding article, written by Gregory Travis, a pilot for 30 years and a software developer for more than 40.
How the Boeing 737 Max Disaster Looks to a Software Developer - Design shortcuts meant to make a new plane seem like an old, familiar one are to blame
(I searched to see if it had been posted before, so apologies in advance if it has been)
A short excerpt . . . .
"So Boeing produced a dynamically unstable airframe, the 737 Max. That is big strike No. 1. Boeing then tried to mask the 737’s dynamic instability with a software system. Big strike No. 2. Finally, the software relied on systems known for their propensity to fail (angle-of-attack indicators) and did not appear to include even rudimentary provisions to cross-check the outputs of the angle-of-attack sensor against other sensors, or even the other angle-of-attack sensor. Big strike No. 3.
None of the above should have passed muster. None of the above should have passed the “OK” pencil of the most junior engineering staff, much less a DER.
That’s not a big strike. That’s a political, social, economic, and technical sin."
John Comley
Unread post by jimdavis » Sun Jul 07, 2019 1:02 pm
Geezzz John I wonder if that's not a bit harsh. I think strike Nos.1 and 2 are pretty common today. I suspect that a hell of a lot of aircraft use electronics to improve the pilot/aircraft interface. Aren't all Airbuses basically in that category? And a lot of fighters are totally unflyable without computes interfering. Come to think of it yaw-dampers are very much the same thing.
To me the above seem pretty normal and it is just strike 3 that seems to be the real green person in the woodpile.
StressMerchant
Closest Airfield: Cab
Has liked: 10 times
Been liked: 88 times
Unread post by StressMerchant » Sun Jul 07, 2019 1:36 pm
I doubt it is dynamically unstable in the aeronautical sense.
- Douglas Adams
