Has liked: 31 times
Been liked: 601 times
Unread post by cage » Sun Mar 10, 2019 4:39 pm
200 hours as a FO. Is that right?
Has liked: 31 times
Unread post by cage » Sun Mar 10, 2019 4:40 pm
Jasondn78 wrote:
Sun Mar 10, 2019 4:21 pm
HAAN wrote:
Sun Mar 10, 2019 4:15 pm
List of Nationalisties
Incredible that were no Saffers on the flight.
RIP
Not really a route SA locals would use to get to Kenya.
wingnutzster
Been liked: 29 times
Unread post by wingnutzster » Sun Mar 10, 2019 4:55 pm
HJK 414 wrote:
Sun Mar 10, 2019 10:53 am
Ray W wrote:
Sun Mar 10, 2019 10:48 am
Another B737-800 Max.
Oh dear, another Max ?
That will cause some debate - for sure.
I don't think the aviation market has ever lost airframe's of the same type so quickly after introduction.
JK
Weren't there successive Comet 1 crashes in a similar timeframe? Looking into it it's remarkably similar in terms of how close the first two losses occurred - first Comet crash 26 Oct 1952, 2nd on the 3rd of March 1953 :shock: :shock: This one is a little close to home, hope we're not entering another season of crashes :(
Regardless of what the cause turns out to be, I wonder how this will affect the image of Boeing's new baby? I can't imagine a brand new airframe, on a hyper tested and proven design would fail catastrophically at 380kts!
howzitt
Priming
Closest Airfield: Glasgow EGPF
Has liked: 53 times
Unread post by howzitt » Sun Mar 10, 2019 5:11 pm
Forget about the 200 hour man.
wingnutzster
Unread post by wingnutzster » Sun Mar 10, 2019 5:20 pm
I am not sure if MAX8 employs maneuvre-limiting fly by wire, I don't think so but I just can't imagine a qualified crew as capable as Ethiopian's are supposed to be stressing a brand new airframe to a catastrophic failure in a turn - that and the nature of the wreckage and impact crater look more to me like the recent Prime Air 767 high energy event, no indication they stalled or spun in and no weather to consider a factor so it really is looking a lot like Lion Air if you ask me. I see the Ombudsman is calling for the grounding of the MAX 8 already :shock: :roll:
738
Flaps set for Take off
Unread post by 738 » Sun Mar 10, 2019 5:23 pm
Mustang
Power on stall
Closest Airfield: FATP
Has liked: 185 times
Been liked: 47 times
Unread post by Mustang » Sun Mar 10, 2019 5:33 pm
Interesting information about the possible cause of Lion Air crash on the following link... could the same perhaps have happened just before this crash?
https://amp.cnn.com/cnn/2018/11/28/opin ... index.html
"Aviation is a passion towards greater achievement in life!" - Júlíus Kloków (Mustang)
Piper Cherokee PA28-180
Piper Cherokee PA28-140
Cessna 172
Cheetah Z194
Airwayfreak
Has liked: 36 times
Been liked: 177 times
Unread post by Airwayfreak » Sun Mar 10, 2019 5:34 pm
We all had 200 hours as an F/O at some point
Roger
Closest Airfield: FAPE
Has liked: 147 times
Been liked: 338 times
Unread post by Roger » Sun Mar 10, 2019 5:36 pm
Think it needs to be clarified as to whether it was 200 hours total time or 200 as F/O.
Airwayfreak
Has liked: 36 times
Unread post by Airwayfreak » Sun Mar 10, 2019 5:54 pm
Quite right. Ethiopian Airlines do have a MPL programme and their F/O requirements are vague
wingnutzster
Unread post by wingnutzster » Sun Mar 10, 2019 5:59 pm
737 MAX & NG specs, differences and limitations - http://www.b737.org.uk/737max.htm
OscarKilo
Post Take off checks
Unread post by OscarKilo » Sun Mar 10, 2019 6:00 pm
The high speed on initial climb amd weird vertical profile has got “systems” issues written all over it. I think we can suspect to get a notification shortly that all maxs’will be grounded pending investigation.
I’m not a big plane driver bit do understand some of the systems a bit. If the fmc was programmed correctly shortly after take off vnav and lnav would be armed. If the plane kept on accelerating without increasing the rate of climb either the auto throttle screwed apround (being stuck in to/ga) or any other system/settting related to the vnav profile was messing around.
The second one which is less believable for me as that after vnav and lnav arming the pilot flying did not follow the flight director. As said. Highly unlikely for me.
And big plane uncles please care to comment and correct me if wrong.
Golf Tango
Been liked: 31 times
Unread post by Golf Tango » Sun Mar 10, 2019 6:04 pm
Could it be nefarious activity?
"I put my finger up and blocked out the whole earth, made me feel incredibly small" - Niel Armstrong
skytrooper
Has liked: 11 times
Unread post by skytrooper » Sun Mar 10, 2019 6:07 pm
Over the years the one question that Always remain: why is there not a Simple override switch, overriding Everything when things go sideways, it's really a simple solution, yet one will hear pages of excuses why it "can't" be implemented. Absolute BS !
Ubluwulululululu....!
Has liked: 1133 times
Been liked: 1448 times
Unread post by jimdavis » Sun Mar 10, 2019 6:17 pm
I suspect the short answer is that Mr Boeing and Mr Airbus think their aeroplanes are smarter than the pilots. And maybe this is true most of the time. But when it really matters then it becomes untrue.
