King Air B300 crash video
Bugs
Steep Turn Right
Closest Airfield: FAPE
Has liked: 17 times
Unread post by Bugs » Mon Sep 02, 2019 12:49 am
Reason: Corrected title to King Air
These users liked the author Bugs for the post:
TomLondon
The Sky is not the end, it is just the beginning of your adventure.
Real Aeroplanes Have Propellers.
Bugs
Steep Turn Right
Has liked: 17 times
Re: KING B300 crash video
Unread post by Bugs » Mon Sep 02, 2019 12:52 am
Major Fatal Accident...
Sunday, 1st of September, 2019
- Philippines 🇵🇭 :
A Private Beechcraft B300 King Air 350, registered RP-C2296, impacted resort buildings and a swimming pole while operating a medical evacuation flight in Pansol, Calamba, Laguna.
The aircraft was completely destroyed during the accident sequence and the two pilots and seven passengers onboard received fatal injures. (9 fatalities)
The aircraft departed from Dipolog Airport (DPL/RPMG) and was headed to Manila-Ninoy Aquino International Airport (MNL/RPLL).
TikkaT3
Taxiing to Clubhouse
Closest Airfield: Potchefstroom
Unread post by TikkaT3 » Mon Sep 02, 2019 7:28 am
Looks like fuel streaming from the wings?
Cessna 182
beckers
Closest Airfield: Republic of Lanseria
Unread post by beckers » Mon Sep 02, 2019 7:48 am
Agree.
Looks like the left wing is shorter outboard of the engines. If you look at other King airs that got over G'd the wings bend, deform, outside of the engines. So my guess is either it got over stressed (G's) or maybe struck something (like trees) prior to the start of the video.
Has liked: 305 times
Been liked: 227 times
Unread post by Ugly Duckling » Mon Sep 02, 2019 8:08 am
Bugs
Steep Turn Right
Has liked: 17 times
Re: King Air B300 crash video
Unread post by Bugs » Mon Sep 02, 2019 10:07 am
This aircraft was fitted with Winglets.
Could it be that both on either wing broke off and played a part in this accident?
2000andmore
Straight and Level
Unread post by 2000andmore » Mon Sep 02, 2019 7:03 pm
It appears as though both outer wing sections are missing, hence fuel being lost. Also loss of roll control. My investigation would focus on a high speed decent exceeding Vne and both ailerons fluttered, causing structural failure of the outer wing panels. If it was an over G case, only one wing would fail.
Poor souls.
Gavin Lundie
HJK 414
Closest Airfield: abcd
Has liked: 53 times
Been liked: 282 times
Unread post by HJK 414 » Mon Sep 02, 2019 9:03 pm
Poor souls.
I am struggling to see whether there was fuel coming from the wings against the cloud cover / before it crossed the ridge initially.
Is it possible it clipped the trees crossing that ridgeline - and we then see the fuel dispersing behind the damaged wings ?
JK
2000andmore
Straight and Level
Unread post by 2000andmore » Tue Sep 03, 2019 8:38 am
So hard to see. You may well be right.
Gavin Lundie
Dragon
Has liked: 102 times
Been liked: 41 times
Unread post by Dragon » Tue Sep 03, 2019 10:41 pm
That could be fuel trails, but with those weather conditions- low cloud and looks humid- if you pull serious G you are also going to pull lovely vortices from the wing tips, although it does look stronger on one side than the other which favors the fuel scenario. At first glance it looks to me like he has pulled really hard and fast out of a dive and damaged his empennage (not sure if it’s just my phone refresh rate, but it looks skew)and wings, and probably other control surfaces, lost control from that and gone in.
Has liked: 131 times
Been liked: 128 times
Unread post by richard C » Wed Sep 04, 2019 8:06 am
That sort of makes sense - suddenly pops out of IMC straight into terrain and has to perform some desperate avoidance maneuvers, damaging the airframe.
Grant all equity and dignity.
yesbhobho
Unread post by yesbhobho » Fri Sep 06, 2019 9:26 am
What would the result if the wing attachment bolts snapped?
To know Him
Winchman
Unread post by Winchman » Fri Sep 06, 2019 9:48 am
More dramatic than what we see here. I would imagine it would result in immediate separation of the wings from the fuselage, especially with the apparent G loading judging by the turns executed. I am sure there is someone better qualified than me to comment.
Stuart Burgess
Fairchild UC61K in rebuild. Hanger 17 Stellenbosch
