Slots and private flights at FAOR, FACT and FALE?
Has liked: 28 times
Been liked: 142 times
Unread post by heisan » Fri Sep 13, 2019 1:31 pm
After reading this thread:
viewtopic.php?f=9&t=222830
I started reading the regs regarding the slot system. From what I can tell, no flights may be operated to/from FAOR, FACT or FALE without a slot. But, due to some weird complexities in the wording of the slot regulations, it seems private flights can only apply for regularly scheduled slots.
I know private flights to FAOR are rare, but it seems FACT and FALE are regularly used for private flights. How is this requirement handled at these airports?
Thanks,
Justin
southside
Steep Turn Left
Closest Airfield: around
Been liked: 46 times
Re: Slots and private flights at FAOR, FACT and FALE?
Unread post by southside » Fri Sep 13, 2019 2:11 pm
Just phone CAMU, get a slot and go. Straight forward.
Has liked: 335 times
Been liked: 75 times
Unread post by ACE MAN » Fri Sep 13, 2019 2:21 pm
A VFR non scheduled departure does not require a slot.
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
Swampdonkey
Has liked: 14 times
Been liked: 12 times
Unread post by Swampdonkey » Fri Sep 13, 2019 2:22 pm
Thanks,
Justin
A good summary of the system is here: https://www.atns.co.za/PDF/Products%20a ... E%2010.pdf
Has liked: 28 times
Unread post by heisan » Fri Sep 13, 2019 2:42 pm
Strangely enough, the regulations don't seem to make allowance for such an exception:
19. Prohibition on using a coordinated airport without a slot
(1) Subject to sub-regulation (2), no aircraft operator may operate at a coordinated airport without a slot allocated by the coordinator in terms of these regulations.
(2) The prohibition in sub-regulation (1) shall not apply to military, police or medical emergencies, humanitarian flights, the use of an aircraft in connection with natural disasters or search and rescue operations, or to in-flight emergencies relating to the operation of the aircraft.
Unread post by ACE MAN » Fri Sep 13, 2019 7:55 pm
The key words there Justin, is coordinated airports.
IITYWTMWYBMAD
Nomakhanjani
¯¯VAF¯¯
Has liked: 28 times
Unread post by heisan » Fri Sep 13, 2019 8:15 pm
Which is why I refer specifically to FAOR, FACT and FALE (which are the only coordinated airports currently listed).
These users liked the author heisan for the post:
Aquila
Unread post by Aquila » Sat Sep 14, 2019 1:02 pm
If you file a flight plan the system will automatically assign you a CTOT. If you file it on FIle2Fly you can view it under "SLOT" once it has been assigned. Whether that CTOT is convenient to you or not is another story. The point is anyone can fly into or out of FAOR/FACT/FALE but you'll need a flight plan to obtain that CTOT. We used to do many charters in and out of there and the procedure was to file a flight plan in advance and obtain your CTOT. Things like parking and handling agents also need to be arranged though because trying to get to and from the Terminal from Delta apron without them isn't going to work...
Raccoon jet driver...
See Horizons!
Has liked: 28 times
Unread post by heisan » Sat Sep 14, 2019 1:21 pm
Thanks. It seems then that the actual slot regulations are largely ignored then. Instead going with a more relaxed on-line system managed by ATNS.
While this certainly makes life easier, I do wish that they would update the underlying regulations - as technically a lot of what is happening now seems to technically be illegal...
Aquila
Unread post by Aquila » Sat Sep 14, 2019 1:27 pm
The systems seems to work though for the non-scheduled operators?
See Horizons!
Has liked: 28 times
Unread post by heisan » Sat Sep 14, 2019 1:44 pm
It seems to work perfectly well - it would just be nice if they updated the underlying regulations to match what is happening now.
CockpitCat
Flaps set for Take off
Unread post by CockpitCat » Tue Sep 17, 2019 8:49 pm
Not sure if this post also refers to GA training flights?
We were recently awaiting departure from FALE, but was informed by the crew that we'll be waiting a few minutes due to "training flights in the circuit", presumably those were GA.
In the end we waited about 10 minutes before departing...
