Ultra IBEC for CDI ignitions
Importers and distributors for GP Engines, Falcon Propellors, Topmodel Cz, Emcotec, Tech Aero products, MINTOR motors and Fromeco. We also stock, RCEXL products, Walbro carb Spares, Futaba and a wide variety of other products. Please visit our website at http://www.cmchobbies.co.za for details. Contact us on 033 3433388. We ship countrywide. You can also join us on Facebook and keep up to date with specials.
Moderator: CMC Hobbies
CMC Hobbies
Commercial Supporter
Unread post by CMC Hobbies » Thu May 17, 2012 8:52 pm
We have been appointed distributorship for the tech-aero range of RC products
Tech-Aero - Ignition Battery Eliminator Circuits for CDI ignitions ( IBEC) - includes opto kill switch amongst its great features........
R545,00 each (remember this saves you both the cost of an additional ignition battery as well as a seperate opto kill switch) also means there is one less battery to charge and less weight in the airframe.
* Eliminates the need for a separate ignition battery and mechanical on/off switch.
* Compatible with the power requirements of single and multi-cylinder model CDI ignition modules via jumper selectable 5V, 5.3V, 6.1V and 6.6V voltage outputs.
* Enhanced flexibility and safety via transmitter control of CDI ignition power from a receiver auxiliary channel.
* Tech-Aero exclusive 4 stage filtering removes interference from CDI ignition noise in the wiring path to the receiver, permitting use with 2.4 GHz Spread Spectrum and 72 MHz FM radio receivers. *
Filter stages 1 & 2: An advanced 2nd order common mode LC power lead filter.
Filter stage 3: Triple power filter capacitors form a low pass filter and enhance peak impulse current delivery to the CDI module.
Filter stage 4: An optical isolator circuit prevents any stray noise from feeding back into sensitive receiver electronics via the signal lead.
* A high precision, very low dropout power regulator design further assures power receiver bus isolation with superior performance during peak current demand.
* One IBEC model fits all: compatible with any battery technology commonly used for radio control use, with a usable input voltage range from 4.8V to 10V.
* Bright 5mm LED CDI power on/off indicator with mounting bezel.
* High reliability Surface Mount components reduce weight to only 17 grams and a size of 25 x 45mm.
* Heavy duty 22 gauge twisted wire power extensions.
airframes from .50 glow up to 220cc gas, and all required accessories
Go to http://www.cmchobbies.co.za
phone - 073 5007177
email info(at)cmchobbies.co.za
CMC Hobbies
Re: Ultra IBEC for CDI ignitions
Unread post by CMC Hobbies » Wed Jun 26, 2013 8:13 pm
phone - 073 5007177
Return to “CMC Hobbies”
