TSA Models
Moderator: Goblin Hobbies
- Commercial Supporter
- Has liked: 0
- Been liked: 0
TSA Models
We are proud to annouce we are officially the TSA Exculsive Distributor in South Africa.
All models are availble from us.
Exclusive Distributors for Goblin Helicopters, AleeS Rush 750, Outrage Fusion 50, Gens Ace Batteries, Beastx, Rail Blades, MKS Servo and MSH Heli and Brain FBL in SA.
- Has liked: 0
- Been liked: 0
Re: TSA Models
- 8000 Tousand
- Closest Airfield: FAPE
- Has liked: 143 times
- Been liked: 319 times
Re: TSA Models
For the novice - how does the sizes match up - is the 600 mean a 600 size ?
- Has liked: 0
- Been liked: 0
Re: TSA Models
Hi Skybound,
Yes the TSA 600 is a 600 size helicopter which swings 600-620mm main blades. These helicopters are super strong and fly extremely well.
600N Specifications
Full length of fuselage 1230mm Fullweight( approx) 3540g
Full width of fuselage 215mm Engine class 50 ~ 55 Nitro
Height 390mm Full tank capacity 650cc
Main blade 600 ~ 620mm Material specification Carbon fiber
Main rotor diameter 1345mm Tail rotor drive shaft drive
Tail blade 90mm Swashplate angle 120°
Tail rotor diameter 252mm
Main gear ratio 14T : 122T
Tail gear ratio 113T : 25T
Gear ratio 8.7 : 1 กG 4.52
600 electric specifications
Full length of fuselage 1230mm Fullweight(12s
500mAh approx) 4885g
Full width of fuselage 215mm Engine class(12s KV) 3,000 ~ 11,000W / 500 ~ 550KV
Height 390mm Power battery 6 ~ 12S Li-Po 3200 ~ 5000mAh
Main gear ratio 11T / 12T / 13T / 14T: 122T
Gear ratio 9.0 / 9.69 / 10.5 / 11.45 : 1 : 4.52
Further details can be found on our website http://www.goblinhobbies.co.za/helicopter-kits/tsa.html or you can email us sales@goblinhobbies.co.za .
Thansk for your interest
600N Specifications
- Has liked: 0
- Been liked: 0
Re: TSA Models
Some more pics of our heli in action
- Has liked: 0
- Been liked: 0
Re: TSA Models
TSA 700N with YS 91 SRX Tareq motor and Hatori pipe. All available from us with spares to back up the heli and parts.
Amazing power and performance from YS, hatori and TSA models. Best combination
- Has liked: 0
- Been liked: 0
Re: TSA Models
Huge shipment of TSA arrived. Get your kit today before stock is out again these kits move fast.....
- Has liked: 0
- Been liked: 0
Re: TSA Models
- Has liked: 0
- Been liked: 0
Re: TSA Models
TSA 600E Pro in action. Amazing flight by Luigi.
All one needs is a PRO model. Good Qualtiy and well priced.
http://www.youtube.com/watch?v=cdz12RHgVss
- Has liked: 0
- Been liked: 0
Re: TSA Models
