Tips & Tricks #4: Attaching pictures or files is really simple now.
Tips and Tricks to get the most out of your AvCom experience.
Roger
Closest Airfield: FAPE
Has liked: 53 times
Been liked: 171 times
Unread post by Roger » Tue Jan 19, 2016 8:19 pm
After our reboot, it has become even simpler to add pictures and files to your posts.
The below video demonstrates the two methods of attaching files.
1 - Using the Attachment Dialogue
2 - Drag and Drop into the message text box
Also take note, as demonstrated, you may now select multiple files at once.
Our current limits allow you to add up to 10 attachments per post, and no single file can be larger than 1mb.
Play video below for the demonstration. (Not embedding it as forcing it to full screen.)
https://www.youtube.com/v/L_CZyTqxcjU
GeraldNagel
Re: Tips & Tricks #4: Attaching pictures or files is really simple now.
Unread post by GeraldNagel » Thu Jan 21, 2016 8:08 pm
Excellent.
HJK 414
Closest Airfield: abcd
Has liked: 54 times
Been liked: 309 times
Unread post by HJK 414 » Mon Jan 25, 2016 1:40 pm
Roger,
when you have time ....
Can you explain how to "capture" more than one quote in a message .....
If I respond to a message - I can quote from a previous message ...... and under the message I can scroll down the page on which the message I am quoting from is on.
Yet if I wish to use multiple previous messages - from perhaps pages further back than the one I am on .......and extract pieces as quotes - from different posting by different members ......how do you go about that ??
Thx
JK
Iceberg
Has liked: 31 times
Been liked: 60 times
Unread post by Iceberg » Wed Jan 27, 2016 12:37 pm
If I attach a .pdf file, is there a method whereby the file is already 'open', i.e. one can read it directly, like a photo is seen directly?
The sky is not the limit....
ZS-MDK
Karl Eschberger
HJK 414
Has liked: 54 times
Unread post by HJK 414 » Wed Jan 27, 2016 3:41 pm
Iceberg wrote:If I attach a .pdf file, is there a method whereby the file is already 'open', i.e. one can read it directly, like a photo is seen directly?
Justin - I have been messing about with that as well.
Solution - the only one I could find......that works.
Open the file on your PC - then save it as a picture ....
and then add the whole thing as a picture.
I can not find any other way ....
JK
Bergie
Closest Airfield: Phisantekraal
Unread post by Bergie » Thu Jan 28, 2016 10:54 am
How would I change the sequence of the attached photos?
Roger
Has liked: 53 times
Unread post by Roger » Thu Jan 28, 2016 11:10 am
Once all the pics are uploaded, click the "Place Inline" button in the order in which you wish them to be displayed. This inserts the [img] tags into your posting. Even if you got the order wrong at that stage, simply moving these tags around one can not only change the order, but also place the pictures in between text if you like.
hugo_visser
Been liked: 44 times
Unread post by hugo_visser » Fri Jan 29, 2016 5:16 am
Morning Roger,after posting a photo it displays in full, when I look at it again later the bottom cuts of, what am I doing wrong ( Photo section seen at Petit )
Hugo.
Roger
Has liked: 53 times
Unread post by Roger » Fri Jan 29, 2016 8:00 am
hugo_visser wrote:Morning Roger,after posting a photo it displays in full, when I look at it again later the bottom cuts of, what am I doing wrong ( Photo section seen at Petit )
Hugo.
Being discussed here : viewtopic.php?f=306&p=1689516#p1689516
Mike Gough
Been liked: 22 times
Unread post by Mike Gough » Sat Jan 30, 2016 5:50 pm
Often on my Mac, many pictures are not displayed, but have 'image' instead.........?
www.skyhawk.co.za
COMPASS Pilot Aptitude Assessment
Roger
Has liked: 53 times
Unread post by Roger » Sun Jan 31, 2016 8:06 pm
Mike Gough wrote:Often on my Mac, many pictures are not displayed, but have 'image' instead.........?
That will appear on any image that had been uploaded before 2012.
Return to “Using the Forum - Tips & Tricks”
