an introduction to performance based navigation (PBN) and RNP
Jayson v Schalkwyk
Closest Airfield: Himeville
Been liked: 52 times
Unread post by Jayson v Schalkwyk » Mon Jul 01, 2019 3:46 pm
I was doing some online training and was sent to this Eurocontrol link. I am not sure that I could past the 20 page document here but the link is provided for those who would like more info on PBN and the differences between RNAV and RNP. Yes, its Eurocontrol focused, but the ideas and concepts are universal.
https://www.eurocontrol.int/sites/defau ... -a-rnp.pdf
Jayson van Schalkwyk
tansg
Power off stall
Closest Airfield: OMAA
Has liked: 67 times
Been liked: 85 times
Re: an introduction to performance based navigation (PBN) and RNP
Unread post by tansg » Thu Jul 04, 2019 6:48 am
Am considering whether it would be worth my while to present similar type courses at obviously the non-$ prices but it would depend on the interest. Ideally I would also link it through a local training organisation for the accreditation at the SITA etc. So who's interested?
Iceberg
Has liked: 41 times
Been liked: 126 times
Unread post by Iceberg » Thu Jul 04, 2019 7:56 am
I am intereseted. I have the equipment in my plane to do GNSS approaches, but have not done the course yet.
I've done practise GNSS approaches in VMC, using my GTN650, Aspen and the autopilot. Works great. With all the beacons disappearing it will become a necessity.
I'll be visiting Aero Africa today and inquire there as well.
The sky is not the limit....
ZS-MDK
Karl Eschberger
moosp
Has liked: 10 times
Been liked: 53 times
Unread post by moosp » Sun Jul 07, 2019 1:41 pm
sg for the record, yes I would be interested in a PBN course. I come from an RNAV 1 and basic RNP background but retired before PBN really kicked in so I have been left behind.
Like Iceberg I have a GTN650 which is crying out to be used more and I find that even in VMC PBN makes sense to find unfamiliar airports with IFR approaches.
Cessna Cardinal C177RG
Cornell Blok
Has liked: 214 times
Been liked: 39 times
Unread post by Cornell Blok » Mon Aug 05, 2019 1:44 pm
I'm installing a GNT 650 this week in our 235 and would like to know if the aircraft itself needs to be approved for Rnav approaches :?:
http://www.flynationwidevirtual.com/
Iceberg
Has liked: 41 times
Unread post by Iceberg » Mon Aug 05, 2019 2:40 pm
Yes it does. I'm busy with mine through Century Avionics.
In the meantime I did the RNAV course through Simuflight in Midrand - I can recommend them.
Did a practise RNAV approach at FAWB in VMC with the knowledge I gained on the course, the plane flew it beautifully on the GTN through the AP.
At FAWB the VOR/DME and WB NDB are out - that leaves only the RNAV approach. Sign of the times.
ZS-MDK
Karl Eschberger
Trevor Duane
Has liked: 50 times
Been liked: 79 times
Unread post by Trevor Duane » Mon Aug 05, 2019 3:12 pm
So glad to be reading this after our previous discussions on GNSS approaches. =D>
Defense Contractor/Test Pilot
Commercial pilot,Instructor
Responsible Person Aircraft
TopRC HawkerHunter
JetLegend ViperJet
BVM F80
1/3 J3 Cub
ZS-VVR
J3 Clip'd Wing Cub Replica ZU-XXX
UAVManufacturer www.pegasuas.co.za
https://youtu.be/Aux7J7H0DHI
tansg
Power off stall
Has liked: 67 times
Unread post by tansg » Tue Aug 06, 2019 6:07 am
You welcome :D Welcome to the future. One of my legacies to SA. 8)
MemyselfandI
Hee Hee I'm Flying
Been liked: 17 times
Unread post by MemyselfandI » Tue Dec 03, 2019 1:44 pm
I just stumbled across this thread. Tansg, do you have any info or insight how this would apply to ATC separation? Reason I'm asking is because I attended a PBN course almost a year ago but found it to be more specific to the requirements to comply with PBN/RNAV and not about separation from an ATC point of view. Any thoughts on this?
tansg
Power off stall
Has liked: 67 times
Unread post by tansg » Sun Dec 08, 2019 6:57 am
Got no "Rydaars" in at work today to check with but will post as soon as I have checked with one of them.
MemyselfandI
Hee Hee I'm Flying
Unread post by MemyselfandI » Tue Feb 04, 2020 9:08 am
Anything Tansg ?
tansg
Power off stall
Has liked: 67 times
Unread post by tansg » Tue Feb 11, 2020 6:11 am
Anything Tansg ?
Sorry I took so long. It is contained in ICAO Doc 4444 PANS-ATM Chapter 5.4 Horizontal Separation specifically
5.4.1.2.1.3 By use of different navigation aids or methods. Lateral separation between aircraft using different
navigation aids, or when one aircraft is using RNAV equipment, shall be established by ensuring that the derived protected
airspaces for the navigation aid(s) or RNP do not overlap.
5.4.1.2.1.4 Lateral separation of aircraft on published instrument flight procedures for arrivals and departures.
5.4.1.2.1.4.1 Lateral separation of departing and/or arriving aircraft, using instrument flight procedures, will exist:
a) where the distance between any combination of RNAV 1 with RNAV 1, or RNP 1, RNP APCH or RNP AR
APCH tracks is not less than 13 km (7 NM); or
b) where the distance between any combination of RNP 1, RNP APCH or RNP AR APCH tracks is not less than
9.3 km (5 NM); or
c) where the protected areas of tracks designed using obstacle clearance criteria do not overlap and provided
operational error is considered.
Note 1.— Distance values contained in a) and b) above were determined by collision risk analysis using multiple
navigation specifications. Information on this analysis is contained in Circular 324, Guidelines for Lateral Separation of
Arriving and Departing Aircraft on Published Adjacent Instrument Flight Procedures.
Note 2.— Circular 324 also contains information on separation of arrival and departure tracks using
non-overlapping protected areas based on obstacle clearance criteria, as provided for in the Procedures for Air
Navigation Services — Aircraft Operations, Volume II — Construction of Visual and Instrument Flight Procedures
(PANS-OPS, Doc 8168).
Note 3.— Provisions concerning reductions in separation minima are contained in Chapter 2, ATS Safety
Management, and Chapter 5, Separation Methods and Minima, Section 5.11.
Note 4.— Guidance concerning the navigation specifications is contained in the Performance-based Navigation
(PBN) Manual (Doc 9613).
This is carried on further in the Chapter for various scenarios.
ICAO Circular 324 provides the background information as to how these seperations were derived.
If you need copies of these docs PM me your email
MemyselfandI
Hee Hee I'm Flying
Unread post by MemyselfandI » Tue Feb 11, 2020 7:59 am
Thank you, I have access to those docs, much appreciated.
