New MGL product : MX1
Induna
Closest Airfield: FASD
Has liked: 136 times
Been liked: 152 times
Re: New MGL product : MX1
Unread post by Induna » Fri Dec 06, 2019 10:59 pm
Kibim wrote:
Fri Dec 06, 2019 10:57 pm
I realised my question was asked of the wrong piece of kit. I was thinking radio not intercom.
No worries. The V16, N16 and A16 are all remotely mounted devices which needs an interface to be controlled by. Either an iEFIS or Razor. The MX1 does not have a built in radio.
Jacques van der Westhuizen
ZS-WSW | Sonerai 2L
Closest Airfield: Ermelo
Has liked: 133 times
Been liked: 773 times
Unread post by Whirly » Sat Dec 07, 2019 6:48 am
Kibim wrote:
Fri Dec 06, 2019 10:47 pm
Whirly wrote:
Fri Dec 06, 2019 1:32 pm
My MX1 is on the way from Rainier, can't wait to see it work. :D
Also got the A16 audio panel and V16 radio.
Santa visited you nice and early. Great shopping basket there. I still have a few months before I can upgrade, but I have the same items on the list.
I'm tempted to get a Vega to run the radio and free up some screen real estate on the MX1.
I am also installing a Garmin GTR 200 Radio and a Trig TT22 Transponder (the most expensive piece in this whole set up). All will be driven by the MX1. The only item that will be visible in the panel, except the MX1 is the Garmin radio. :D
rainier
Has liked: 33 times
Been liked: 184 times
Unread post by rainier » Mon Dec 09, 2019 2:34 pm
Just to clarify:
V16: COM radio module (dual frequency with RX on two frequencies with priority on main frequency - also includes the "say again" playback).
N16: NAV radio module (Dual/triple frequency receiver - dual VOR or VOR + Localizer and glideslope). It is the lowest cost navigation receiver on the market by quite a margin and has some pretty good specs to boot.
A16: (up to) six place, dual circuit stereo audio panel (intercom system) with lots of functionality, wired inputs, bluetooth phone and music streaming as well.
T16: Transponder. This has not yet been released but is in development. Mode-s with ADS-B out.
All of the above are modules you can squirrel away in a suitable location to favor wiring and accessibility for maintenance work.
They are controlled via "heads". Heads come in various flavors and each of these items can be controlled my more than one head if required. Currently heads for all of the above are MGL iEFIS (all variants including the MX1), Vega (2.25") and Razor (3.18") panel mount heads. The A16 can only be used with a Razor as it needs a bit more screen real estate (or an EFIS).
Older MGL EFIS systems like the Odyssey and Voyager can also be used (provided the hardware is at least G2 or has been upgraded to that level).
The V16 and N16 can be used individually or combined in non-MGL EFIS systems if at least a Vega or Razor head is used - via this the combo can emulate various types of radios that use the Apollo protocol (i.e. SL40, SL30 and the newer variants from big "G").
The form factor of all of the above modules allows the creation of a "super module" which should be out next year - this combines the A16, up to two V16 and N16 radios into a single module - greatly reducing wiring and installation effort even further.
Rotor kop
Closest Airfield: OR Thambo
Has liked: 1077 times
Been liked: 143 times
Unread post by Rotor kop » Fri Feb 14, 2020 10:15 pm
This is all french to me. I want a radio that has 3 cables...one plugs into the aerial, one into my headset socket (somewhere #-o ) and the other to the power source 8)
Unread post by Whirly » Sat Feb 15, 2020 7:12 am
Must it have at least an "on/off" knob? :lol:
Rotor kop
Unread post by Rotor kop » Sat Feb 15, 2020 7:13 am
Ja just one. It can have a volume knob to but i dont use that much...just on and off is shap :wink:
Induna
Unread post by Induna » Sat Feb 15, 2020 8:17 am
I received my shiny new MX1... just need to install it now 8)
These users liked the author Induna for the post:
Rotor kop
ZS-WSW | Sonerai 2L
Rotor kop
Unread post by Rotor kop » Sat Feb 15, 2020 8:19 am
Induna where are you based? I am interested in putting a semi-glass panel in one of my aircraft. However i only have 2 left hands and a standard 1 when it comes to installing stuff like this :oops:
Unread post by Whirly » Sat Feb 15, 2020 8:26 am
My installation should be completed next week. :D
Induna
Unread post by Induna » Sat Feb 15, 2020 9:07 am
I am based at FASD. They are quite simple to install. I will be putting it into the gyro and just keep the ASI and ALT steam gauges as a backup. The hardest part will be preparing the fiberglass instrument panel.
I will post some pics when done (before and after)
Rotor kop
ZS-WSW | Sonerai 2L
Rotor kop
Unread post by Rotor kop » Sat Feb 15, 2020 9:12 pm
Another question, can the v16 use the xtreme efis as a head?
Unread post by Whirly » Sat Feb 15, 2020 9:21 pm
RK,
You are aware these can only be used in NTCA?
Rotor kop
Unread post by Rotor kop » Sat Feb 15, 2020 10:03 pm
RK,
Yes
rainier
Has liked: 33 times
Unread post by rainier » Sun Feb 16, 2020 8:00 pm
No unfortunately not. The XTreme has no provision at all to interface to any COM radios.
Rotor kop
Unread post by Rotor kop » Sun Feb 16, 2020 8:06 pm
Okay thank you. So the cheapest option without going razor head would be mx1?
