CPL HELICOPTER PILOT REQUIRED
Pilot Jobs relating specifically to rotor wing aircraft
Forum rules
vvpgm1@gmail.com
Closest Airfield: Newcastle
Unread post by vvpgm1@gmail.com » Thu Aug 22, 2019 5:01 pm
Vacancy exists for a helicopter pilot in Newcastle, Kwa Zulu Natal.
Candidate must be prepared to re-locate. The pilot is required for a private use aircraft, Chopper R44.
Starting salary depending on years experience. Please contact Jeanne on 0747148783.
Last edited by vvpgm1@gmail.com on Tue Aug 27, 2019 12:55 pm, edited 1 time in total.
Stephen Robertson
Been liked: 10 times
Re: CPL HELICOPTER PILOT REQUIRED
Unread post by Stephen Robertson » Fri Aug 23, 2019 12:28 pm
Hi Jeanne.
I can't seem to get through on the number provided. Please post or PM me an email address or an alternative number.
Regards,
Stephen
If you are depressed, you are living in the past.
If you are anxious, you are living in the future.
If you are at peace, you are living in the present.
- Lao Tzu
Jadon Lovemore
Closest Airfield: FANC
Unread post by Jadon Lovemore » Fri Aug 23, 2019 6:45 pm
Hi Jeanne,
The number you have supplied definitely does not put us through to you. I would be very interested in this opportunity but we can’t contact you.
Has liked: 374 times
Been liked: 276 times
Unread post by Ugly Duckling » Fri Aug 23, 2019 6:55 pm
Try
27747one4878tree
Return to “Helicopter”
