Draco down
Mike Wissing
Closest Airfield: KBDN
Has liked: 17 times
Been liked: 128 times
Re: Draco down
Unread post by Mike Wissing » Sun Sep 22, 2019 3:12 am
Anybody thought about what effect the soft tundra tyres would have on the takeoff roll - especially the right one that was carrying a lot of the load? :D
BTW: the standard 2000's crosswind component is 15 knots - my hangar neighbor has one. Stall speed is not that impressive either - 48KIAS.
Mike Wissing
C.A.P. Search and Rescue Mission Pilot - SAR Check Pilot.
Professional RV builder and company test pilot
I can't wait for computer keyboards to come out with a breathalyzer..........
Wingnutter
Has liked: 74 times
Been liked: 123 times
Re: Draco down
Unread post by Wingnutter » Sun Sep 22, 2019 3:45 am
Draco was anything but standard - wing chord was substantially increased amongst other STOL mods.
These users liked the author Wingnutter for the post:
R 22
"Pilots take no special joy in walking"
Has liked: 1133 times
Been liked: 1448 times
Re: Draco down
Unread post by jimdavis » Sun Sep 22, 2019 5:54 am
How do the gross and empty weights compare between Draco and the 2000?
Mike Wissing
Has liked: 17 times
Re: Draco down
Unread post by Mike Wissing » Sun Sep 22, 2019 6:10 am
I'm very familiar with Draco!
Do you think those modes increased or decreased the x-wind capabilities?
Mike Wissing
Re: Draco down
Unread post by jimdavis » Sun Sep 22, 2019 6:50 am
Mike, it seems to stand a lot taller. That alone will make it less happy in a crosswind.
Mike Wissing
Has liked: 17 times
Re: Draco down
Unread post by Mike Wissing » Sun Sep 22, 2019 6:54 am
Draco - 2400/4000
Wilga 2000 - 1980/3300lbs
A lot of info on Draco here:
He says the fuel burn on an IO- 540 is 28 gph..... :shock:
He says his turbine burns the same as the piston. Bull dangle!
He added 16" to the gear legs.
Reason: Embed the YouTube link
Mike Wissing
Re: Draco down
Unread post by jimdavis » Sun Sep 22, 2019 8:48 am
Draco - 2400/4000
Thanks Mike. So it's a lot taller and more likely to be blown over - which is pretty much what happened.
Broadbandboer
Closest Airfield: FASC
Has liked: 36 times
Been liked: 17 times
Re: Draco down
Unread post by Broadbandboer » Mon Oct 21, 2019 11:38 am
It seems that he is rebuilding...
Nico van der Linde
ZS-ETT C182
Deanw
Has liked: 32 times
Been liked: 323 times
Re: Draco down
Unread post by Deanw » Mon Oct 21, 2019 12:00 pm
See https://avcom.co.za/phpBB3/viewtopic.php?f=1&t=224281
http://www.SAairforce.co.za
homebuilt
Closest Airfield: FAEL
Been liked: 121 times
Re: Draco down
Unread post by homebuilt » Tue Oct 22, 2019 12:44 pm
Surely by lifting the front gear and in its present stance, the high engine would further restrict the airflow over the front cowl that goes past under the lee side wing further decaying lift on that wing. In actual fact I am surprised that any air at all goes over the front of the fuse and then under the far side wing. All the lift in that strong a cross-wind will collect under the near side wing and almost none at all under the far side especially with almost no forward speed.
