1970 Piper Cherokee 140 Airframe For Sale, with Photo’s
Forum rules
No commercial adverts please (If your intended post is of a commercial nature, then please follow this link and read BEFORE you post : http://www.avcom.co.za/phpBB3/viewtopic.php?t=54617). If you are advertising for a friend - the ad must contain the owners contact details. If you wish to advertise in the commercial section: - email ads@avcom.co.za for more information. Model Aircraft and non aviation item's have their own section - any posted here will be deleted.
Sundownerman
Closest Airfield: Lanseri
Unread post by Sundownerman » Mon Oct 14, 2019 8:56 pm
Aircraft Make and Type: Piper Cherokee 140
Year Model: 1970
Airframe Hours: Approx 10,500
Engine Type and Hours: N/A
Prop type and Hours: N/A
Avionics and other equipment: Partial
Reason for sale: Airframe Only/Project/Parts
Viewing Location: Lanseria
Price: R 100,000 (No VAT applicable), come and view and make offer ?
Other information: See below
Contact details of owner: 0833753000
Pictures:Interior, Exterior and Panel Views
See below
This Cherokee has an engine failure in flight and pilot managed to put her on the ground, but ran into a ditch on the roll out, which bent the nose gear leg and dinged the nosebowl
Whilst I have the last set of logbooks, there is no engine or prop/spinner or LG legs, wheels or brake units - just the LG castings attached to the spar
Other missing parts = avionics, instruments, rudder, trim unit in tailcone (Brackets are there)
Fuselage mostly complete, with vertical fin and top fairing plus rudder top fairing, all seats (need recover), door, latches, flap handle with cover, control wheels, rudder pedals with pilot side brakes, throttle quadrant with levers, centre console, all glass panels usable, tailcone fairing halves
Both wings have the fuel tanks (with caps!), flaps and ailerons (1 aileron has a small split in T/Edge), plus wing tips. Main spar attach brackets look good on visual inspection, but the leading edge and trailing edge attach brackets do show some Corrosion = will need to be de-riveted and replaced
Stab is complete with trim tabs and both tips, flaps, wing & stab tips plus 1 aileron
Engine mount and nose-bowl both slightly damaged, with both top and bottom cowling halves in good shape
This project would probably suit a flight school with a fleet of Cherokees as a parts donor
Pls PM or call for more detail or to schedule a viewing
Enjoy every flying minute, and every minute flying
Has liked: 627 times
Been liked: 230 times
Re: 1970 Piper Cherokee 140 Airframe For Sale, with Photo’s
Unread post by Ray W » Wed Oct 16, 2019 11:45 am
Way back in 1975
Sundownerman
Unread post by Sundownerman » Wed Oct 16, 2019 5:20 pm
Hi Uncle Ray
Tx for the Nice photo :D
In my album 👍
That is where she should be
Looks a little sad now, but perhaps somebody could refurb her and get her back there - or her parts will keep another you get lady in the sky ?
Rgds Matt
Air Bear
Unread post by Air Bear » Thu Oct 17, 2019 2:20 pm
8-[ 8-[ 8-[
These users liked the author Air Bear for the post:
Go Low, Go Fast, Turn Left
Keaton Perkins
(Formerly Rare Bear)
Sundownerman
Unread post by Sundownerman » Sat Oct 19, 2019 11:12 pm
Now that is a first !!
Never seen or heard of a Cherokee taildragger
Tx for that Air Bear
Sundownerman
Unread post by Sundownerman » Tue Nov 05, 2019 3:11 pm
Bump
Anyone need Cherokee parts ??
Make a reasonable offer 🙏
Sundownerman
Unread post by Sundownerman » Mon Dec 02, 2019 10:29 pm
Bump Up
Any offers ?
Sundownerman
Unread post by Sundownerman » Thu Jan 09, 2020 12:17 pm
Bump
Will look at a Time-X airframe as a part trade if you have and need Cherokee parts ?
Cessna 150/152, old 172, early Mooney or other Cherokee
Return to “Aircraft for Sale”
