Check the damaged horizontal stab where portions of the vertical stab struck it
And according to reports the crew were not even aware of it !
Or the Embraer 120 Flight 2574 that crashed due to horizontal stab leading edge departing after being only partially secured with half the fasteners in maintenance? Quite staggering that this still happens although thankfully in modern airliners the most critical parts for sustaining stable flight are not simply screw-fastened
Boeing calls the missing piece forward of the vertical stabilizer the dorsal fin.wingnutzster wrote: ↑Thu Jun 11, 2020 2:37 pmLooking at the structure, there are at least 9 formers all attached at the roots to the fuselage former stations - surely only one or two were loose forward causing enough stress in flight to cause all 9 attachment points to give way?!
Screen Shot 2020-06-11 at 14.28.25.pngScreen Shot 2020-06-11 at 14.32.50.png
By "attached" I meant bolted/fastened sorry, so there's 14 bolts? My point was how do 14 fastened (attached) points fail at once?RiNCEw1ND wrote: ↑Sat Jun 13, 2020 9:53 pmBoeing calls the missing piece forward of the vertical stabilizer the dorsal fin.wingnutzster wrote: ↑Thu Jun 11, 2020 2:37 pmLooking at the structure, there are at least 9 formers all attached at the roots to the fuselage former stations - surely only one or two were loose forward causing enough stress in flight to cause all 9 attachment points to give way?!
The formers of the dorsal fin do not attach to any fuselage structure. The dorsal fin is a separate assembly with a seal at its bottom edge and is bolted to the fuselage from the inside through the upper fuselage structure using 14 bolts.
My guess is the bolts didnt failwingnutzster wrote: ↑Wed Jun 17, 2020 10:28 pmBy "attached" I meant bolted/fastened sorry, so there's 14 bolts? My point was how do 14 fastened (attached) points fail at once?RiNCEw1ND wrote: ↑Sat Jun 13, 2020 9:53 pmBoeing calls the missing piece forward of the vertical stabilizer the dorsal fin.wingnutzster wrote: ↑Thu Jun 11, 2020 2:37 pmLooking at the structure, there are at least 9 formers all attached at the roots to the fuselage former stations - surely only one or two were loose forward causing enough stress in flight to cause all 9 attachment points to give way?!
