Gavin did you have the O-200 engin?2000andmore wrote: ↑Mon Aug 10, 2020 3:26 pmI flew her for 15 years and had loads of fun. A very good and reliable little aircraft.
Drakensburg - Wild Coast - Hluhluwe flying
- Frequent AvComer
- Has liked: 1 time
- Been liked: 153 times
Re: Drakensburg - Wild Coast - Hluhluwe flying
- HASSELL checks
- Closest Airfield: FACT
- Has liked: 8 times
- Been liked: 21 times
Hi Neville,
BLX has a Continental C85. Quite adequate for the job and leaves the Cubs far behind
The Taylorcraft has a NACA 23012 airfoil which is the secret to its "speed" and good flying characteristics. The Cessna Citation and Caravan and many other successful aircraft still use it.
It's nice to see you having fun in a Taylorcraft.
Best regards,
Gavin
Best regards,
Gavin
Gavin Lundie
- HASSELL checks
Glen Dell used to own her before the rebuild by Tim Kearton. Seen here with her original registration on what is now the golf course at Cathedral Peak Hotel. Glen was on his way to the Margate airshow.
- These users liked the author 2000andmore for the post:
- Cornell Blok
Gavin Lundie
- Seven Thousand
- Has liked: 247 times
- Been liked: 58 times
Wow what a blast from the past2000andmore wrote: ↑Tue Aug 11, 2020 11:15 amGlen Dell used to own her before the rebuild by Tim Kearton. Seen here with her original registration on what is now the golf course at Cathedral Peak Hotel. Glen was on his way to the Margate airshow.
- Fower Tousand
- Has liked: 272 times
- Been liked: 79 times
I'm reluctant to ask this; but in this photo (above) the engine appears to be running and there are still stones/rocks under the wheels...strange?
- HASSELL checks
BLX never had an electric starter, so "chocks" and a prop swing were required. I guess whoever took the photo was the starter
Gavin Lundie
- Fower Tousand
Ah, that makes sense, then: thanks, Gavin.
- 10000 and still climbing
- Closest Airfield: Ermelo
- Has liked: 191 times
- Been liked: 886 times
I looks like there is someone inside though.2000andmore wrote: ↑Wed Aug 12, 2020 5:28 pmBLX never had an electric starter, so "chocks" and a prop swing were required. I guess whoever took the photo was the starter![]()
