G3x Touch GEA 24 needed
Closest Airfield: FAPX
Has liked: 291 times
Been liked: 847 times
Unread post by Chalkie » Sat May 14, 2022 3:48 pm
Hi Guys, I posted a thread on the Maintenance thread.
I need to borrow a GEA 24 to see if mine is faulty, before I send it back to the USA.
Can anyone help? Thanks.
Oh, Guru. Pray tell, what is the secret to happiness and contentment.
Never argue with an idiot.
Oh, but I disagree!
Yes; you are right.
Re: G3x Touch GEA 24 needed
Unread post by Chalkie » Fri May 20, 2022 9:14 am
Amazing how easy it is to confuse a computer, GIGO comes to mind. When setting up the RPM indicator I ASSUMED that RPM 1 was LH Mag P-lead and RPM 2 was the P-Mag fitted to the right. WRONG...
A simple thing like that confused the GEA 24. Looking at the wiring diagram it was obvious there was no connection to the P-lead and the P-Mag RPM wire went to RPM 1. Setup corrected and my fuel tank calibration was available again!!
Two TOTALLY different snags caused by one assumption...
These users liked the author Chalkie for the post:
Oh, but I disagree!
Yes; you are right.
