Stefan's Safari VLA (700kg-750kg) build progress - ZU-FMF
stefan
Closest Airfield: FARA
Re: Stefan's Safari VLA (700kg-750kg) build progress - ZU-FM
Unread post by stefan » Wed Nov 23, 2011 9:26 pm
Have done lots of work but a bit behind on the pic's. We are now ready for the CAA certification inspection and testing to go ahead.
stefan
Unread post by stefan » Thu Dec 01, 2011 8:08 pm
New 912/914 cowls done and dusted. Aircarft ready for covering. Wings rigged and done. Don't comment on the prop, was only used to get the spinner position.....
overberg
Tripped over wheel chock
Closest Airfield: next to my house
Unread post by overberg » Sun Jan 29, 2012 4:09 pm
Hallo Stefan
How bout an update on your build. Eks vrek nuuskierig!
Namibiese groete
Rocco
stefan
Unread post by stefan » Sun Jan 29, 2012 8:14 pm
Hi Rocco,
Ek is ook haastig maar het nou weer vasgehaak met die papierwerk. Ek wag vir my ingenieur en CAA om nou finaal ooreen te kom wat ek moet toets op die vliegtuig. Dit sal glo die 9de Febr gebeur. Intussen gaan ek aan met die ontwerp van die 4 seater en besig om die D-motor te maak werk op die Explorer, so ek het baie ander dinge wat my besig hou. Ek glo ek sal voor die middel van die jaar klaar wees met die hele approval prossesse. Ek sal julle op hoogte hou.
Walid
Unread post by Walid » Mon Jan 30, 2012 6:45 pm
stefan wrote:Hi Rocco,
Stefan, beplan julle om 'n 4 seater uit te bring ?
stefan
Unread post by stefan » Mon Feb 06, 2012 6:19 pm
Het ek so gese :wink:
Besig met baie dinge............
stefan
Unread post by stefan » Sun May 06, 2012 9:54 pm
OK, so after months of waiting and paper pushing we are finally getting to the point where we will actually test something. We have a technical meeting this week at CAA where we will finalize what needs to be tested. The testing dates are set for the week after next. Lets hold thumbs that nobody at CAA books in sick that week and it gets postponed again.
stefan
Unread post by stefan » Sun Jun 03, 2012 7:38 pm
Eish, I am still waiting. They just have no regard for time or money. When you are in the wrong they are quick to send you warnings and letters but when they are in the wrong, what do you do???? I am still waiting for CAA......Getting very irritated by this now. It's been 4 years
stefan
Unread post by stefan » Sun Aug 25, 2013 10:04 pm
Got hold of a 914Turbo for this project. We will start covering this coming week. Things are moving along at last.
Specs so far
Engine 914 Turbo
Prop - Woodcomp SR3000 3 blade inflight adjustable.
MGL Odyssey
MGL V6 Radio
MGL Xtreme as backup.
stefan
Unread post by stefan » Tue Jun 03, 2014 9:58 pm
New structural testing will be conducted within the coming weeks. The structure was already tested to limit loads before, now we are going for ultimate loads as well as a higher MAUW. Previous test have shown that the wings and cabin structure exceeds the required strenght so we decided to take it to the max that VLA will allow us to go (750kg) This way the aircraft could be used for other purposes as well. There is enough meat in the system. So for Amateur build aircraft you will be able to fly at 750kg and for production build aircraft you will be able to flay at 700kg. At 750kg MAUW we will have approximately 370kg useful load. With these kind of carrying capacity the addition of floats, crop spraying equipment and so on start to make sense. There will be a min engine hp requirement of 100hp for VLA aircraft.
this one has a Rotax 914 Turbo and a Woodcomp CS prop. Future models will also have the option to fit the Rotortec/Weber engines. These engines are already approved in Germany and produce 70-150hp for 84kg installed weight on the Turbo model. A new V4 is also in the making that will produce 200hp. I have seen them fly in the Rotortec Gyro's in Germany and they are a winner.
stefan
Unread post by stefan » Thu Jun 12, 2014 10:45 pm
Structural test are scheduled for the first week in July. We are eventually moving ahead.
Arjan
Lining Up - unmanned
Closest Airfield: Brits
Been liked: 13 times
Unread post by Arjan » Mon Jul 14, 2014 8:34 pm
Are we still on track ?
ZU GAS ( Whisper TMG )
ZS GLH ( Astir Glider )
ZU MAS (Zenith CH640 )
ZS GWK ( DG 505 M. SL “for sale” )
ZS GAH ( Falke SF25C “sold” :( )
ZS GFH ( Focke Wulf Kranich II )
D-EWHI - ZU WAS (Wilga PZL35 - in rebuild)
ZU IMD (Wide Hawk)
stefan
Unread post by stefan » Mon Jul 14, 2014 8:37 pm
Our engineer fell ill and was hospitalized so we moved everything forward. Waiting for CAA to set the new dates but should be by the end of July or early August. All the rigs are set up at the factor, we are ready to go.
stefan
Unread post by stefan » Sat Aug 30, 2014 3:35 pm
Everything is now handed in at CAA. In the meantime we did our own testing and took the wing to 700kg and 3,8g. Absolutely no problem. Looks like we might up the amateur build category to 750kg. Official testing should be within the next week or 2
stefan
Unread post by stefan » Fri Nov 14, 2014 8:59 pm
I am happy to report that after many years of struggling with certification we have finally completed the ultimate load tests with CAA today. All test were successful. All first time. First design and first time passed. No re-building or re-doing. We did 4 test, 1 negative load remaining
All loads were at point A on the Vn diagram @12degr
1 - Limit load, symmetrical - Required load 970 kg/wing - actual load - 1030kg/wing (700kg @ 3,8g)
2 - Ultimate load symmetrical. Required load 1470kg/wing actual load - 1530kg/wing (700kg @ 3,8g plus 150%)
3 - Limit load, A-Symmetrical. Required load R/wing - 570kg L/wing - 970kg
4 - Ultimate Load A-symmetrical Required load R/wing - 863kg L/wing - 1470kg (actual weights were much higher but I do not have the numbers with me)
Return to “Bushbaby”
