Bushbaby photos
stefan
Closest Airfield: FARA
Re: Bushbaby photos
Unread post by stefan » Wed Mar 07, 2018 10:51 am
PH-JOO
Has liked: 79 times
Been liked: 67 times
Re: Bushbaby photos
Unread post by V5 - LEO » Sat Apr 28, 2018 9:08 am
...what is the advantages of the new droop tips??
stefan
Re: Bushbaby photos
Unread post by stefan » Sat Apr 28, 2018 9:51 pm
They are not new, its an option. The stall is a mile or two lower but apart from that, some guys prefer the look.
Flooi
Closest Airfield: FAHG
Has liked: 31 times
Been liked: 17 times
Re: Bushbaby photos
Unread post by Flooi » Sun Apr 29, 2018 6:00 am
And wear a hat. They sometimes attack you.....
Hennie van Zyl
ZU-IEU Jabiru J170 D
Has liked: 79 times
Re: Bushbaby photos
Unread post by V5 - LEO » Sun Apr 29, 2018 8:06 am
...ok txs, looks fine but prefer the straight wing.
Johan Swakopmund
Taxiing to Threshold
Closest Airfield: Swakopmund
Has liked: 33 times
Been liked: 34 times
Re: Bushbaby photos
Unread post by Johan Swakopmund » Wed Jul 25, 2018 2:56 pm
Bushbaby no 45 -- V5-UOL
Aircraft completely stripped to bare metal.
All frame etc rust protected and resprayed- new seconite and professional painted
All bolt , nuts , washers etc replaced with new from Kitplanes
New bungees ,tires-- windscreen and doors new
Complete new wiring done.Some gauges replaced with new ( eg oil temp and intermittent hobbs )
Engine is Jabiru four cylinder with water-cooled cylinder heads with radiator moved to sit
under cockpit and electric circulation pump.
Fly hands off from first flight for near to four hours after rebuilt and temperatures run in green ( can
be nicely controlled with manually switching of water circulation pump as needed)
Small finishing touches to be done and GPS to be installed
Was a stressful eight months of rebuilt to get materials etc but my son Pieter is a happy chappy today
regards
Johan de Wet
Stefan jy is reg dit is no 45 :D
Last edited by Johan Swakopmund on Thu Aug 02, 2018 11:01 am, edited 1 time in total.
NAMIBIA FLYING COUNTRY
Has liked: 79 times
Re: Bushbaby photos
Unread post by V5 - LEO » Wed Jul 25, 2018 3:13 pm
....Johan jy en Pieter het great werk gedoen, weet julle het hulp gehad maar steeds, die aerie lyk bevange. =D> =D> =D>
stefan
Re: Bushbaby photos
Unread post by stefan » Wed Jul 25, 2018 3:25 pm
Bushbaby no 43 -- V5-UOL
regards
Johan de Wet
Hi Johan, Is jy seker oor die serial nommer? My rekords het hom as 45.
Lyk baie mooi.
Has liked: 79 times
Re: Bushbaby photos
Unread post by V5 - LEO » Wed Jul 25, 2018 3:48 pm
...Stefan is daardie blou pou nog by jou en beskikbaar?
stefan
Re: Bushbaby photos
Unread post by stefan » Wed Jul 25, 2018 4:06 pm
Has liked: 79 times
Re: Bushbaby photos
Unread post by V5 - LEO » Wed Jul 25, 2018 4:15 pm
.....joh sy lyk mooi - een simpel vraag asb dalk, is daar 'n manier om dalk so 30kg ekstra payload te kry, ek en my laaitie is stewig kerels en as die trippie bietjie ver raak is die sous min?
Johan Swakopmund
Has liked: 33 times
Re: Bushbaby photos
Unread post by Johan Swakopmund » Wed Jul 25, 2018 4:33 pm
Hi Stefan
Jong ek twyfel nou sterk oor die nommer.
Sal ou logboeke nagaan en vergelyk
Maar sy vlieg damn lekker
Julle mag maar BOS BABAS bou
Stefan ek het een vraag -- die sitplekke is leer en sit gemaklik maar ek wat kort is druk my kop skeef
teen die skuins strut / pyp van agter na voor. Is daar n beter oplossing9( kyk op die wiite se foto sit die piloot ook skuins kop )
En kan jy my n koste gee vir n hidrolies rem stelsel -- Net voorsien ons sal self insit.
Die drom brieke is niks werd en net gewig wat jy saam sleep
groete
Johan
Last edited by Johan Swakopmund on Wed Jul 25, 2018 4:55 pm, edited 1 time in total.
Johan Swakopmund
Has liked: 33 times
Re: Bushbaby photos
Unread post by Johan Swakopmund » Wed Jul 25, 2018 4:47 pm
Leopold
As jy belangstel kom dadelik Swakop toe
Hier is nou Dawid Visser ( Namib Scareways ) se geel een mer n 582 enjin en Pieter
sin mer die Jabi enjin. Jy kan beide gaan vlieg.
Die 582 se syfers is dieselfde as ons sin - spoed - gewig optel etc.
Jy sal nie weer een kan kry soos Stefan nou het vir daardie prys nie.
Wys jou net self doen is nie altyd goedkoper as om dit deur Stefan of Boet of Jean te laat doen nie
Johan
Has liked: 79 times
Re: Bushbaby photos
Unread post by V5 - LEO » Wed Jul 25, 2018 5:01 pm
....Johan, wil Dawid verkoop of bedoel jy die verskil maak nie saak tussen die 582 of Jab nie? ek hou nogal van die 582, dink hulle probleempies is redelik uitgesort? Ek hou BAIE van die een wat Stefan nou het, sal net beter brieke ook posit, wil plaas toe vlieg, so benodig stop krag :D
stefan
Re: Bushbaby photos
Unread post by stefan » Wed Jul 25, 2018 5:10 pm
Hi Stefan
groete
Johan
Hi Johan, Ek het gesien julle het limo seats daar in. Die beste is om los kussing te gebruik direk op die fiberglass.
Ek het n tweede handse (met baie min ure Matco sisteem) stuur my 'n e-mailo dan stuur ek die pryse. info @ saplanes.co.za
Return to “Bushbaby”
